Question about Watches
Blac label watch battery replace - Watches
JSprings Movement, Seiko VF62, battery change
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
Jan 22, 2013 | Watches
How to change the battery in a CASIO CA53W-1 Watch with Calculator
open up the watch. there is a small spring that could fall out. dont lose it. use a small pin to pull battery clip off. put new battery in, replace strap and pink plastic. short the tiny contact labeled AC with the + on the battery. check that the clock now operates. lastly, reassemble
there is a spring inside that goes betweeen one of the contact holes. dont know which.
Jun 03, 2010 | Casio Watches
HOW TO CHANGE BATTERY ON AN OAKLEY BULLET WATCH
Open the watch case back, release the upper contact (unclip or unscrew it), memorize the writings on battery and the way the battery was placed in. Buy exactly the same battery, insert the same way in and close watch case back. Reset the watch and you are done. Some watches need a shortcut to be made before resetting. This should be written on the label covering the battery. Rate me, plz.
Mar 15, 2010 | Oakley 4 D Bullet Watch Titanium Case with...
Does not run. does this watch have a battery in it?
There are two types power sources for watches. Automatic and battery.
Automatic needs to be either wound by the crown (winder on the side) or wound by the movement of the wrist while it is worn.
The battery powered is self explanatory.
Since you didn't include the model it's difficult to say for sure because Relic makes both automatics and battery powered watches. Although I can tell you is most automatics will clearly labeled. If your watch say automatic somewhere on the face or back you need to contact Relic for service because your watch has a 12 year warranty.
To prevent violating your warranty a jeweler should be the one who replaces the battery if it is battery power.
I included the link to Relic watches below for info on the warranty and instructions.
Hope this helps.
http://relicbrand.com/
Nov 13, 2009 | Relic Multifunction Watch
I just replaced the battery on my polar watch and 'error' and the number 6 is on the screen. Nothing i do will unfreeze this or change it. Have already tried to take the battery out and put back in
You probably need to "short out" the battery before you can set it.
To do this you need to remove the caseback and apply a tweezers to the battery and the "AC".
The AC is usually labeled and it looks like a little gold cricle near the battery in the watch. (I realize there may be more than one gold colored small circle in there, and if it's not labeled it will take trial and error.)
With the tweezers, or paperclip would work, touch the AC and the battery at the same time and hold for a few seconds, then release and repeat once more. This should get your watch reset and ready for you to set.
Oct 23, 2009 | Polar F6 Wrist Watch
How do I reset thebattery on a casio ad-520?
To reset the battery you need to locate the "AC" inside your watch. The AC terminal is a little metal spot (usually a circle and usually gold colored) on the inside of your watch. Looking at the inside of your watch the "AC" should be labeled, though it may take a magnifier to identify it.
It may be labeled simply "AC" or it may have an arrow pointing to it. Once you locate it use a pair of tweezer or a paper clip and touch the battery and the AC together for a few seconds and release; you may have to do this twice. This will reset your watch an give you the ability to correctly wet your watch.
Oct 21, 2009 | Casio Marine Gear AMW320D9EV Wrist Watch
Battery replacement for a G-shock.
The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Replace battery on a casio gshock.
good morning ! you need to short the reset poin on the bord of your watch after that you see the digit will apear on LCD then start to set the time use the setting button to set the time date and day ! thank you ! god bless !
Dec 16, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Watches Logo
29 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
