We can only get a picture on sky, not digital free view
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
SOURCE: 37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
SOURCE: Failed to receive broadcast E202 Sharp
What do you mean exactly when you say "failed to receive broadcast"? Does it not get a signal of any sort? What about from DVDs, do you have a DVD player attached, does that work? Did it used to work just fine with regular TV signal?
Thanks, let me know more and I can definitely help!
Tim
SOURCE: I dont want to use
you need a antenna with digital capabilities.you can generally find them cheap and make sure tv is set on antenna instead of cable.
SOURCE: Failed to received broadcast E202. what's
It means that the tv doesn't gets the correct signal from the cable or the antenna - check them.
