Connect sound bar to sony receiver str dh540 - Audio Players & Recorders
5 Suggested Answers
SOURCE: Sony STR DG 510 receiver manual
Hey there, found it on the sony site...
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=STRDG510
Hope that helps.
Posted on Oct 19, 2007
cancerags
  • 36 Answers
SOURCE: connecting sony str/k660p to dvd recorder and tv
Hello jvirgil,
Go to http://esupport.sony.com/US/perl/model-home.pl?mdl=STRK660P&LOC=3
and under the hot topics section, click on "Hookup Recommendation Guide", select the components you want to hookup (Dvd recorder and receiver in your case. TV hass been autoselected). Click continue, select all the different inputs/outputs that your components have, click on Recommend my Hookup and... 'voila' you get your personalized connection guide. Hope this helps.
cancerags
Posted on Dec 27, 2007
OnlyOneN
  • 86 Answers
SOURCE: How do I connect my Lenovo X200 Tablet to my new
Couple things to be aware of:
1. The X200 is not available with a Blu-Ray drive. So, your HD content will need to come from somewhere else, such as downloading from iTunes. Alternatively, you can purchase an external Blu-Ray drive. (it may be cheaper / easier to buy a dedicated Blu-Ray player if that's the route you want to go).
2. The X200 only has analog audio output. The only surround you'll be able to receive is Dolby Pro-Logic, provided your source material has it encoded that way. You can connect your laptop to the receiver via a 1/8" to RCA adapter, available at virtually any electronics retailer. (Buy the cheapest one you can find) Connect the 1/8" plug to your headphone jack on the laptop, and the white and red RCA connections to any available input on the back of your receiver. (such as CD, AUX, DVD, etc.) Select that input on the front of your receiver and you'll hear the output of your laptop. Enable surround sound processing (pro-logic) on your receiver. Check the manual for instructions on how to do that.
3. Purchase a VGA cable (I recommend monoprice.com ). I suggest staying under 15' for optimal quality. Connect one end to your laptop, and the other to the PC-in on the back of your TV. Select that input using your TV's remote. (On my Sony, I press Menu, External Inputs, then PC)
4. Set up your laptop to use the external monitor. I suggest leaving your laptop off till you plug in the VGA cable. If upon booting your laptop is outputting to the TV display, usually a key combination such as Shift-F7 will enable it.
Alternatively, your TV has an 1/8" audio input jack that goes along with the PC input. If you've connected the audio out of the TV to your receiver already, the audio from your laptop can pass through the TV to the receiver. 1/8" cables can also be purchased from Monoprice.com.
Let me know if that helps!
Posted on Apr 20, 2009
SOURCE: no sound from Sony STR-DH500 when playing dvds with HDMI
no sound via hdmi cables, you must use optical or coaxial
Posted on Dec 18, 2009
My receiver says the speakers are off
Maybe you can update the speaker driver to see whether it is a driver problem.
Apr 09, 2015 | Sony STR-DH540 5.2-Channel Home Theater...
How do I get solve this problem: the str-dh540 has no output?
Take everything to the nearest Sony-authorized repair depot, for professional trouble-shooting and repair.
May 20, 2014 | Sony STR-DH540 5.2-Channel Home Theater...
How to connect a teac equalizer A220 to a Sony receiver str-DH540
I'm not familiar with your units. The most common set up would be use the "tape monitor loop". Eq out to receiver tape in monitor, Eq in to receiver tape out monitor, then engage receiver "tape monitor" switch on.
Mar 18, 2014 | Audio Players & Recorders
I cannot get components to work through sony str-dh540.
two things come to mind
- Low input voltage
- Power supply issues
Low Power
As multiple items are having issues the issue sounds that a wiring issues. Have you tried another receptacle (plug) perhaps another room Try plugging only a light to the plug. Does it flicker or appear dim. A multi meter to check line level and a polarity tester to check that wiring is correct. A good power bar will have a polarity tester built in.
Power Supply.
When you must turn on and off a device before it starts working suggests that components have partially failed. Bad capacitors can exhibit this type of issue.
It is possible that a power issue is damaging your hardware. It is always best to use a good power bar. Passive bar are good for a few years. Active should work well for many years. Balance the cost of a power bar to the value of your equipment.
Jul 18, 2017 | Sony STR-DH540 5.2-Channel Home Theater...
Video in not working
When you plug the AV cables into the receiver make sure that the channel that it is plugged into is selected on the front of the receiver. Also note that the receiver should have a monitor output that should be plugged into the TV and the TV input must be selected on the TV.
Jan 31, 2014 | Sony STR-DH540 5.2-Channel Home Theater...
I have the sony: STR-DE 685. The sound in the
This sounds like a very poor connection. Please make a new splice on speaker and receiver. This should take care of this for you.
Feb 26, 2010 | Sony STR-DE597 Receiver
No sound from Sony STR-DH500 when playing dvds with HDMI
Dec 10, 2009 | Sony STR-DH500 A/V Receiver
Can't get Playstation3 sound through the STR-DG800 using HMDI.
Do you have your ps3 connected to the TV with HDMI and then audo cables from the TV to the receiver? If so, you need to make sure you change the audio settings on your TV to surround sound.
May 12, 2009 | Sony STR-DG800 Receiver
STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Jul 06, 2008 | Sony STR-DG800 Receiver
21 people viewed this question
 Grubhead
Grubhead
