Question about Charging & Starting Systems for Lexus CT 200h
Charging lexus ct200 with cigarette lighter socket
Are closed hood car jump starter any good
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
SOURCE: 1998 lexus es300
Anyone having this problem should be aware that there is a second cigarette lighter inside the bottom of the console. You should check to see if that unit is working or not as well. If both units are out, you could have a bigger problem. You wouldn't want to replace the lighter unit and have it still not work.
Posted on Aug 18, 2008
  • 38 Answers
SOURCE: blown fuse 2007 lexus es 350
LOOK FOR THE FUSE BOX IT WILL SAY [ CL ]for CIG LIGHTER FUSE MITE BE A 30 JUST LOOK FOR THE FUSE BOX OR SEE LEXUS DEALER IT AN 2007 MAYBE 35DOLLARS OR LOOK YOURSELF
Posted on Apr 25, 2009
WhoownsaCRT
  • 4 Answers
SOURCE: cigarette lighters dont work?
Stop smoking and it won't be a problem
Posted on May 30, 2009
SOURCE: all three cigarette lighters in 2006 lexus rx 330
most probably its a fuse. go to your manual and it'll indicate the location of your fuse box. most likely there are two under the left and right engine bay covers. pop the fuse covers and you'll find the fuse for the lighters. this info is also in the manual.
Posted on Jun 25, 2009
Danniboi
  • 1098 Answers
SOURCE: cigarette lighter doesnt work on 2008 lexus is 250
Most likely a fuse, or a faulty lighter.
Posted on Jan 15, 2010
My cig lighter dose't work in my 1992mitusbishi Galant
possible blown fuse or bad ground check wiring to make sure all wires are pluged in if so replace lighter
Feb 08, 2016 | Cars & Trucks
Clicking noise from under hood before it turns over. sometimes won't start, but will start when jumped. battery is good.
battery may not be good have it load tested --also alternator and starter tested---clicking would be starter solenoid trying to get starter to turn over ---check the connections at battery and starter for loose or corrosion
Aug 22, 2015 | Cars & Trucks
Accord 2007 will not start... something clicks under hood 1 time
Check the starter solenoid. One click and no crank is a pretty good indicator that the solenoid on the starter is no longer doing it's job. A new starter will usually solve this issue.
Feb 26, 2015 | 2007 Honda Accord Coupe
Where do I plug in the cord to start charging the jump starter (Black & amp; Sage ) 900 peak ,350
Google for an owner's manual. I can't find anything on this jump starter, but first they need to be charged, usually by plugging into a wall socket for 12-24 hours. Then plug into the cigarette lighter for 10 min or so to give the car battery a boost charge.
Dec 04, 2014 | Cars & Trucks
How can I change the cigarette lighter fuse in Toyota Avalon 2005?
Changing the fuse in the fuse box wont solve your problem On the back of the socket that is mounted in the dash that the lighter pushes into has a inline fuse that if over heated will blow. You will have to change the lighter. Toyota wanted close to $70 for a replacement lighter for my Tacoma. I never used the cigarette lighter for cigarett but needed to charge my cell phone so I replaced it with a dash Mount 12 Volt Power Socket for $10. Good luck.
Sep 26, 2014 | 2005 Toyota Avalon
How do I know the battery status on my Stanley 350 amp jump start ? When I push the button it always lights up all 3 lights regardless of how much charge is on
I have a more basic version from Home Depot. From day 1, the charge indicator never worked correctly. Have had it several years now and probably by this time, the battery is just getting weak and needs to be replaced. I found that charging by the cigarette lighter doesn't work too well. Charging by the AC adaptor overnight is the best and I do it every 4 months. Once and a while, I test it by connecting to an old starter motor. If it spins at decent speed, the charge is OK. The cigarette lighter plug connection is also good to use when you need to change the car battery and don't want to loose all your radio presets. It backfeeds the system and keeps all battery powered systems powered when the main battery is disconnected.
NEVER run the engine without the main battery connected! Good way to burn out all your electronics.
Jul 07, 2014 | RoadPro Road Pro 12 Volt Dc Portable...
04 ford explorer change starter,battery now the car won't start
check your main fuse under the hood ,try jumping your starter ,turn your ignition on and jump the starter you may need a starter or try tapping your starter while somebody else is turning the key to start
Mar 01, 2014 | Cars & Trucks
How can I jump the starter on my 91 camaro?
hot wire starter you can short out ignition switch and wiring. to jump starter ignition switch start postion.you have to run 10 gauge jumper wire from the starter solenoid positive battery terminal to starter switch or S terminal on starter solenoid this procedure take two people but better remove starter replace starter solenoid. trying jumping off starter on camaro would be dangerous you have jack up car to get to starter and wiring person laying under car hot wiring starter while other person hold ignition start position put person under car in deadly position just remove starter have auto parts check it out first replace starter or solenoid if either bad. easier hot wire starter if starter under hood like my 1977 vega monza had starter at top could take long screw driver jump starter off.on the four cylinders engines back in the 70s. camaro starter under car dangerous trying to hot wire not a good idea.
May 07, 2013 | Cars & Trucks
I have 1999 Toyota Highlander with Pursuit Series Model 08SPr remote starter in it. I left the lights on battery ran out. I started car with jump. After that everything works except the remote start. I...
Check the hood pin switch. It's located under the hood around the edge of the engine compartment. It's designed to make contact with the hood when the hood is closed. Also, check for a remote start shutdown toggle switch under the dash.
Jul 20, 2011 | Car APS921 Remote Starter - Keyless Entry
Charging & Starting Systems for Lexus CT 200h Logo
42 people viewed this question
Top Lexus Vehicle Parts & Accessories Experts
Timllfixit
Colin Stickland
Colin Stickland
Hugh Mckernan
Hugh Mckernan
Level 1 Expert
Are you a Lexus Vehicle Part and Accessory Expert? Answer questions, earn points and help others
