Question about Nina Shostopper Shoes for Women
Nina shostopper shoes battery replacement
How do I replace the battery in this shoe?
Not all the lights are working in my led shoes.. what should I do?
Those wires in the shoe are actually delicate and subject to damage from constant vibration. Depending on the shoe, the lights and wires, batteries may be in the sole. If that is the case you can pull the liner out and check to see if you can access the electronics. It may be sealed though.
May 20, 2016 | Clothing Accessories
How do I change the batteries?
sorry to say
The battery cannot be replaced. The battery and the electronics controlling the blinking lights for the shoes are encased in a solid block of plastic (Plastic like material). Let's just say that you are willing to drill or saw your way through the plastic to get to the battery. (I was) This plastic brick is inside the heel of the shoe and can not be gotten at without stripping the seams for the bottom of the shoe. I assume, that unless you are skilled cobbler, there is no way to replace the battery without destroying the shoes.
Feb 08, 2014 | Skechers S Lights Terminal Shoes
How do you change battery in Carter's kids light up shoes
There is a battery in the insole. Lift the insole and the battery will be in the heel
Jan 20, 2013 | Carters Carter Match Light-Up Shoes at...
How do I clean spots off of Ivory Nina Electra shoes?
Call the local shoe repair shops. They may offer to clean them, if not ask if they sell a product called AFTA. it is a cleaner/spot remover. It comes in a small metal can reminiscent of lighter fluid (remember that stuff) DO NOT USE LIGHTER FLUID.
We used AFTA on satin shoes (including dyed bridal shoes) and it worked fine.
Sep 05, 2011 | Nina electra Shoes
How to do a rear brake assembly
if you mean to replace the rear brakes,then you can remove both drums and look at how the brakes are installed and replace one side at a time using the other side to see how the spring system is fastened to the brakes to hold them in place.just remember the rear shoe(of both shoes on one side) is always the longer of the shoes if there is a difference in length of the shoe brake material.some brakes have a long shoe and a short shoe when you look at a shoe and compare it to each of the other shoes.some the shoes are the same length,in which case it won`t make any difference.
Aug 09, 2011 | 1992 Chevrolet Beretta
How to replace battery on skechers twinkle toes shoes
May 27, 2011 | Skechers YouthTween Twinkletoes Pixie Dust...
How do i take off the brake drums on a 2003 chevy cavalier
After you remove the tire, the drim should slide off. If it doesn't then try using a rubber mallet and gently tap on the outside edge as you pull on it. Sometimes you also need to tap on the drum in the center part. I have sprayed penetrating lubes like WD-40 or PB Blaster into the seam at the center. You may also have to back off the parking brake cable or even use the adjuster to back off the shoes.
Jan 27, 2011 | 2003 Chevrolet Cavalier
Hi guys! Got a question regarding apple chip on nike shoes. Is the sensor battery replaceable? How long does it last?
No, the sensor's battery is not replaceable or rechargeable. The sensor's battery has a life of over 1000 active hours. The sensor sends a low battery signal when there is around 2 weeks of life remaining (based on usage pattern), indicating that the sensor needs to be replaced. Battery life will vary considerably based on use and other factors.
Most Nike + iPod runners and walkers can just drop the sensor in their Nike+ shoes and forget about it. When inactive, the sensor enters stand-by mode to save battery life.
Oct 27, 2010 | Clothing Accessories
I think my battery is dead in my Casio Oceanus Wave Cepter watch. It has been stored in a drawer for a couple months and it is not working now. Does it need to put in the sunlight or do I need to replace...
==== <a href="http://www.voguecatch.com" target="_blank">http://www.voguecatch.com</a> ==== ====accept credit card and paypal
Cheap Nike air Jordan shoes33$,Air Force 1 33$, Nike dunks SB shoe,Nike Shox shoe. Wholesale Cheap Nike shoes with discount jersey, High quality T-shirts,ED hardy t-shirts,ED Hardy hoodies,ED hardy shoes,ED hardy Jeans,Evisu shoes,GUCCI shoes,LV Handbag,Chanel Handbag......welcome to ==== <a href="http://www.voguecatch.com" target="_blank">http://www.voguecatch.com</a> ====
Nike shox(R4,NZ,OZ,TL1,TL2,TL3) $35
Handbags(Coach lv fendi d&g) $35
Tshirts (Polo ,ed hardy,lacoste) $13
Jean(True Religion,ed hardy,coogi) $30
Sunglasses(Oakey,coach,gucci,Armaini) $15
New era cap $16
Bikini (Ed hardy,polo) $18
Oct 26, 2010 | Watches
Replace rear shoes
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove the rear wheels.
  3. Remove the drums.
  4. Remove the automatic adjuster spring and lever.
  5. Remove the hold-down clips and pins.
  6. Rotate the automatic adjuster starwheel enough so both shoes move out far enough to be free of the wheel cylinder boots.
  7. Disconnect the parking brake cable from the actuating lever.
  8. Remove the lower shoe to shoe spring.
  9. With the shoes held together by the upper shoe to shoe spring, remove them from the backing plate. 0900c152800c4b3d.jpgKelsey Hayes rear brake assembly (left side shown) 0900c152800c4b3e.jpgExploded view of the drum brake assembly—2004 model shown
GOODLUCK, shoes for this car ~ 15 bucks at auto zone.
May 27, 2008 | 2000 Plymouth Neon
Nina Shostopper Shoes for Women Logo
534 people viewed this question
Top Nina Clothing Accessories Experts
Da Doc
Tom Chichester
ray gallant
Are you a Nina Clothing Accessory Expert? Answer questions, earn points and help others
