Question about Rangemaster Professional 90 SS (electric) Kitchen Range
Ovens not working rangemaster professional 90
Ovens and clock display not working
SolutionGuy
  • 331 Answers
SOURCE: clock and oven inoperative on elan rangemaster 90
Your electronic oven control (clock) has failed. This being a new appliance, it will be covered under warranty. Call the dealer and ask for the manufacturers warranty/customer service phone number or ask if the dealer provides warranty service. You will need to provide them with the Model and Serial number to obtain service, so have this ready when you call. After service is complete, please connect your oven to a quality surge suppression/arrestor device. We recommend these... http://catalog.belkin.com/IWCatProductPage.process?Product_Id=124911 , they can be found here... http://www.belkin.com/wheretobuy/show.aspx?pid=&targ=19&ttr=3e86a31d-23dd-4b8d-acbf-2adf1ce9ecc0&cid=1
Posted on Aug 11, 2007
  • 6 Answers
SOURCE: how to use the ovens without the clock
If your clock is not working we can repair it for you.
www.appliancetimers.com
Howard
Posted on Apr 25, 2008
  • 3 Answers
SOURCE: rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Posted on Nov 24, 2008
SOURCE: both ovens on my leisure rangemaster 100 will not come on
I have a range master cooker, where both ovens do not work, because the clock/timer is not working, but if I switch the griddle/grill on for approx 1 hour everything works fine!! The clock starts flashing, i press reset & switch the ovens on! Once the griddle has cooled down, you have to start the entire process again the following day! This appears to be a vary common fault.
Posted on Jun 24, 2009
  • 160 Answers
SOURCE: Both ovens only light to pilot light, wont go
Faulty FFD's ( flame failure devices) once the flame is established it allows the full flow of gas to the burner... must be a gas-safe engineer to replace part..
Posted on Dec 17, 2009
Clock / oven not working
The display control board may have failed, check for 110v at molex connection, next look for a circuit fuse on the control board. If the above is good, replace control board from eBay.
Dec 22, 2013 | Rangemaster Classic 90 (Electric) Kitchen...
My clock on my Rangemaster Toledo 90 kept switching off last night whilst using it and ovens went off as well turned it back on twice and then the 3rd time it won't come back on. Its dual fuel so the gas...
Power from switchboard > oven circuit cabling > supply terminals of oven > high temp cutout > timer > multifunction switch.
usually the high temp, if so, check the cooling fan is working. Watch out for dodgy crimp connections on the wires (mechanical stripping can nick strands off the wire making a hot spot)
Oct 18, 2013 | Rangemaster Kitchen Ranges
Timer not working - flashing auto permanently so cannot light either of the ovens. Have tried reset but has not worked
Try the 6 push buttons under the clock.
press in the first two buttons from the left simultaneously and then the - and + to adjust the clock. Thats how it works on my Classic 90 but not certain about the 110
Sep 26, 2013 | Rangemaster Proffessional 110 Gas Kitchen...
Their was apower cut now the clock and fan oven wont work. but power to the grill and gas is still functioning . rangemaster 110
where you clock is the buttons next to it, 2 have a line underneath joining to them both, hold them both down together to stop clock flashing, this will then allow your ovens to work, it's a safety feature on these ovens, and to reset clock keep both buttons held in and use the plus and minus button to set hope this helps Donna
Apr 15, 2010 | Rangemaster 110 (Gas) Kitchen Range
New applaince can't set clock, cannot switch on eletric ovens, electric grill works, gas hobs fine
I'm sure you must have had an answer by now, but just incase anyone else has the same issue. The ovens don't work unless the clock has been set (happens after a power cut). To set the clock you need to hold down the left-hand two buttons (underneath the clock) and at the same time press either the + or - button.
Oct 19, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
I have 0.00 and aoto flashing on and off.
After a power failure most digital clocks have the zero's and auto flashing. These ovens will not work if clock(time of day) is not set. By pressing incorrect buttons, you can complicate things further. Recommend turning off power to oven for a few seconds, then follow manual for resetting clock, which is usually holding down the 2 buttons on the left hand side simultaneously, and holding down these two press the + or - key to advance clock.
May 21, 2009 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Both ovens on my leisure rangemaster 100 will not come on
phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
Jan 23, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster Toledo
we had the same problem - a power cut then the clock flashed up 'auto' preventing the oven from working.
After downloading the manual from the rangemaster website we learnt that all you need to do (for the classic dual fuel anyway) is to press in the 2 buttons on the left and set the time using the + or - keys. Dead easy and Christmas dinner is back on!
Sep 02, 2007 | Rangemaster Elan 90 (Dual Fuel) Dual Fuel...
Clock and oven inoperative on elan rangemaster 90
Aug 11, 2007 | Rangemaster Elan 90 (Dual Fuel) Dual Fuel...
Rangemaster Professional 90 SS (electric) Kitchen Range Logo
23 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Mike Carew
paulcarew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
