Question about Bissell 1770 Quicksteamer II Upright Vacuum
My bissell 1770 quicksteamer is not picking up the water
Every time I use the dirty water is not picked up
4 Suggested Answers
SOURCE: Bissell 1770 Quicksteamer ii
Looking for ther dang Instructuion booklet which/which I just saw in last day or so/ and it says what model it is.,,
altho its says quciksteamer right under the Bissel product name on the front up by handle and electrical wire holder--the SOLUTION tube runs down around the mortor housing but NO type of heating unit--So I don't get why the call it QUICKSteamer..is another GUESS
with no water is heated except for when I do use hot water or have boild water--not putting the boilng water in to tank tho=the solution flows FINE--and sems to be flowing from all sprouts
I'm not stupid-
I workled for yrs In MY dads aplpliance Co--we reapired Maytag washer & Dryers which seldom needed fixed...my lint brush I will chech & CLEAN AGAIN-- AND Pretty sure ALL FITTINGS ARE seating PROPERLY--just can get it to SUCK--the dirty water back into holder tank-unsit hasnt been used more than a dozen times..amd has worked preffect all those other times..
Seems when all esle SUCKS the vacum cleaner or Rug Shampooer WON'T
Posted on Mar 04, 2008
  • 29 Answers
SOURCE: bissell quicksteamer 1770
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix. My model is different than yours, but many models are similar.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Posted on May 29, 2009
  • 1739 Answers
SOURCE: What's your problem? how to replace nozzel for bissell quicksteamer
The User Guide for your Bissell 1770 QuickSteamer can be found here:
http://canada.bissell.com/images/UserGuides/1970-2080_English.pdf
Available replacement parts may be ordered online here:
http://canada.bissell.com/Products/p/1770+quicksteamer/ak/replacementparts/Product.aspx
Was not sure if you meant you were having difficulty with actually removing and replacing the nozzle? Please reply if you need further asistance
Posted on Oct 27, 2011
How can I clean or open the bissell quicksteamer dirty tank
Hi Deni! The collection tank can not be opened for cleaning. You may want to fill the tank with some hot tap water and let it sit for about 30 miutes.
Here's a link to our website if you decide to order a new tank.
http://www.bissell.com/parts/?id=9143&sc=part&partid=4482&cid=ccsocial
Jan 16, 2013 | Bissell 1770 Quicksteamer II Upright...
Why wont my bissell quicksteamer **** up the water?
Hey Kailyn, having no suction is a problem. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1092&cid=ccsocial
Jan 12, 2013 | Bissell 1770 Quicksteamer II Upright...
Oct 27, 2011 | Bissell 1770 Quicksteamer II Upright...
Need instruction book for bissell model 1770
Information on your Bissell QuickSteamer 1770 can be found here:
http://canada.bissell.com/Products/p/1770+quicksteamer/Product.aspx
The User Guide for the 1770 /1970 Series is here:
Apr 13, 2011 | Vacuums
How much soap to use in the model 1770
Half a capful per tank of water. Make sure you use the BISSELL 3X Concentrated Fiber Cleansing Formula made for the machine.
See below for the manual.
http://www.bissell.com/assets/0/132/134/228/9367721b-1131-4a4c-b8fc-a7ceef5728e4.pdf
Mar 03, 2011 | Bissell 1770 QuickSteamer Upright Vacuum
I need to know how to use Bissell Quicksteamer model 1770
CLICK HERE for your manual in PDF format.
THanks for using Fixya - a FixYa rating is appreciated for answering your FREE question.
Jun 22, 2009 | Bissell 1770 Quicksteamer II Upright...
Bissel 1770 Quicksteamer II Upright vacuum
Here is a picture breakdown, maybe that will help. Sometimes tho you can run a mixture of vinegar and hot water thru it, it may clean it out ok.
Mar 25, 2008 | Bissell 1770 Quicksteamer II Upright...
Is the front nozzle fitted correctly, Is the tank seated correctly,
On the dirty water tank there is a sponge filter make sure this is clesn,
Nov 19, 2007 | Bissell 1770 Quicksteamer II Upright...
DIRTY WATER
remove the dirty water tank and see if the front nozzle is fitted correctly, also see if the filter is clean on the dirty water tank
Bissell 1770
Go to Sears with the model # and they can order a manual and ship it to your home.
Oct 28, 2007 | Bissell 1770 Quicksteamer II Upright...
Bissell 1770 Quicksteamer II Upright Vacuum Logo
85 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
