Question about Janome D'cor Excel Pro 5124 Mechanical Sewing Machine
How do you thread a twin needle on Jnome Excel 5024
robotek
  • 1512 Answers
SOURCE: instruction manual for janome decor excel 2 5024
The learning centre at http://janome.com/index.cfm/Machines/Electronic/DE-PRO_5124 has help for all things from button holes to quilting. Go to the LEARNING CENTER Goodluck. There is a heap of information at this site. Just do a search for what you are trying to do,
Posted on Feb 03, 2008
Mimito7
  • 128 Answers
SOURCE: howto thread a twin needle on Janome 6019
Hi there. If you have an acessory kit with your machine, there should be a plain spindle with a smaller bottom on it. There should also be a small hole on the top or back of your machine where your thread goes.. And yes you can thread both strands of thread thru the same areas till the needle.
Posted on Apr 28, 2009
  • 161 Answers
SOURCE: how do I thread the machine using a twin needle?
its basically the same as a normal needle, but nearest the needle most machines have a way to divide the thread before the needle hole. Some machines have a left and right thread guide a couple of "steps" before the needle, but at some point they have to travel together, and this doesn't seem to be a problem. Make sure you lessen the tension as there is still only one bobbin thread, and triple check the needle is in the middle and that you are on straight stitch or you might break it!
Posted on Sep 14, 2010
  • 6 Answers
SOURCE: Can I use a twin needle on my Janome MW3018?
Twin needles can be used on any machine. Just make sure you use the correct presser foot......one that allows both needles to work without hitting the foot. Also.........you cannot zig-zag or use any other fancy stitch with a twin needle.......it is strictly for straight sewing. You have to use 2 spools of thread .....thread your machine with both threads as if they were one thread but separate the threads when you get to the needle. There is no change to the bobbin. Happy sewing. I can't be bothered to go to all this trouble so I just sew 2 rows to get the same look. Ofcourse you have to be very good at sewing perfectly straight seams doing it this way. Try both methods on a scrap and see which method you prefer.
Posted on Dec 21, 2010
wentlanv
  • 710 Answers
SOURCE: I own a Jenome Excel
Hi Sarah,
First, check to be sure you are threading the machine correctly. This accounts for most problems.
Try using new thread and carefully rethread top and bottom . If that doesn't take care of the problem, then check the bobbin case and hook for scratches, burrs, nicks, etc.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 14, 2011
Thread breaks on the 2340CV Brother. Doing two needle and the right needle is breaking at the needle. Change needle and retreaded several times
Probably depends what that needle is hitting that is causing it to break. Make sure the presser foot and the needle plate hole are large enough to accommodate the twin needle. Twin needles come in different widths so if yours is too wide, it would break. However, it could be possible that your machine is slightly out of alignment that does not show up until you try to use a twin needle. Also, make sure that your thread is not causing the needle to break--could be misthreading. Some machines have separate guides and tension disks for twin threads. Those that don't have that accommodation may have more difficulty using a twin needle.
Mar 07, 2017 | Sewing Machines
I just need instructions to thread a Bernina Virtuosa 160 for pintucking
Your owner's manual should have instructions for using a twin needle.
Most machines can use a twin needle. However, some machines have two tension disks so one can separate the two threads and get equal tension. (The Bernina 930 has two tension disks, so am assuming your newer machine does also.) Look at the top of your machine where the tension mechanism resides and see if there is a right and left side. In either case, do NOT thread both threads at the same time as the threads can become twisted. When threading the machine, ALWAYS RAISE the presser foot, thread one thread completely. If threading the left side of the tension disk, also thread the left needle. Then thread the second thread, making sure to use the other side of the tension disk and needle.
Just a reminder to be careful using any zig-zag or decorative stitches since a twin needle requires a narrower stitch width to avoid broken needles.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwiawf-507_RAhVHwlQKHQrnAXgQFgg4MAQ&url=http%3A%2F%2Fwww.itsastitchonline.com%2Fmastery_on_the_web%2Fmastery_153qe_163_1-4-02.pdf&usg=AFQjCNHHww3jbxbLXZYNj6vuCZE4-kVa8g&cad=rja
Stitching Odyssey How to use your twin needle
How to use twin needle So Sew Easy
Bernina Instruction Manuals
Jan 13, 2017 | Bernina Sewing Machines
How to use a twin needle on my SR2000 toyota sewing machine
First, verify that your machine can use a twin needle. Most machines take will use a twin needle will have separate thread guides and duel thread spool pins.
To thread it, thread one thread all the way through one of the needles and then thread the second thread through to the second needle. This will help keep the threads from twisting.
Toyota RS2000 Instruction Manual
Aug 25, 2016 | Toyota Sewing Machines
How to thread with double needle
You'll need to use two separate spools of thread. Machines that take a twin needle will usually have separated thread guides and two separate tension disks. Just make sure the threads are not twisted when threading. Might be better to thread one all the way through and then thread the second.
How To Use Twin Needles
Be sure to check the width of your stitch when using a twin needle. Because the needles will be wider than a single needle, it is very easy to hit the needle plate if setting it too wide.
Jun 11, 2016 | Elna 1010
How do I thread my twin needle on my SQ9185 machine correctly so as not to break the needle again. The diagram in the manual is a little "sketchy".
with twin needles
you thread the first needle like you would a single needle and then you thread the 2nd needle then same way
make sure the setting are fixed for a twin needle
Feb 28, 2015 | Brother Sewing Machines
How do I thread to use twin needles on Janome Excel Pro 5124?
here is a link for a manual, the information should be in it about the twin needles Instruction Manual Janome 5124
Jul 27, 2014 | Janome D'cor Excel Pro 5124 Mechanical...
Janome twin needle
you should be able too, I sent you a link for a manual, the information should be in it.
How to thread an excel 5024
here is a link for a manual to buy or you can try youtube and see
if they have any threading instructions
http://www.sewingmachinesplus.com/manual-j-5024-en.php
Jan 21, 2013 | Janome D'cor Excel Pro 5124 Mechanical...
Janome D'cor Excel Pro 5124 Mechanical Sewing Machine Logo
134 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
