Question about Brother Office Equipment & Supplies
How do i set ring for more than 4 , so fax doesnt interrupt answering machine
Brother intell 775
  • 186 Answers
SOURCE: Brother 1270E won't receive faxes
make sure the phone line is plugged into the port marked "line" not "phone"
Posted on Jun 21, 2007
checkitright
  • 1362 Answers
SOURCE: set rings
here is the manual
http://www.retrevo.com/s/sharp+UX-B700+manual
good luck
Posted on Dec 10, 2007
  • 12 Answers
SOURCE: to recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Posted on Mar 28, 2008
SOURCE: can't get this fax machine to work with my answering machine
I have the same problem. I can send a fax, but if I try to receive a fax, the distinctive ring goes off, and it says RECEIVE on the display, but it doesn't receive anything, and there is nothing in the memory. Any ideas? PLEASE HELP!!!!!
Posted on Aug 08, 2008
leroyal
  • 2120 Answers
SOURCE: Brother 4100e Fax Problem - Caller ID won't work with Fax Machine
Usually, fax machines don't have caller ID capability.. If the sender's fax number appears on the faxes you receive, it's just that they have programmed it into their fax machine as a header.
Posted on Sep 12, 2008
I am unable to send a fax brother intelifax 775 fax manual
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
The model of my AT&T answering machine is 1720...it is linked to a Brother's fax machine...when a call comes in I am not able to pick up the phone and interrupt the message from the answering machine...
Connect the telephone line of the answering machine from the series connection of the facts machine
.Now set the number of rings for the answering machine to activate to the maximum.{This is found on the side of the machine as a reed switch.}
Now when the calls comes in there is enough time for you to allow it to the answering machine or to attend a call or to set it to facts if a document is comming.While you are away you have to decide the priority needed for either facts or answering as it is a commonline. If answering machine has to work set the facts to telephone mode.If facts has to work set it to facts as the machine will activate before the answering machine.
Sep 02, 2010 | AT&T Lands Phones
Our fax will not pickup incoming faxes
The mode is correct. You can check the rings to answer setting. Default is 4 rings. If your phone line is just for the fax try setting rings to 1. Sometimes sending fax machines go into redial before the 4th ring.
Also, sometimes unplugging the power for 10 seconds will clear any memory that may have locked up the machine.
Hope this helps.
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
When people call our home number sometimes the fax machine is reached instead of the home number. What would cause that? I called Quest and they said it was a problem with the fax and to call you. Our fax...
Make sure the fax machine is correctly set up for the ring pattern of its number. I suspect it's either not set or set for the wrong ring pattern, and is answering the phone before you do when people call. Once the fax machine is set for the proper ring pattern the problem should clear up.
You can download a copy of the manual here if you've misplaced yours. Just pick your product (fax machine) and model from the drop-down menus.
Mar 13, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Need to silence ringer and have it pick up on first ring
menu, receive option, delay ring, options 0-4 choose 0! Done
Feb 17, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
How do you set the number of rings on a brother 560 fax machine
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Nov 26, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
VERY IMPORTANT
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
To recieve fax on brother
Select Receive Mode
MANUAL
Fax Start
Distinctive Ring
, page 8-1.)
FAX ONLY
FAX/TEL
, page 5-5.)
TAD:ANSWER MACH.
only
do
not
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
16 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
