Question about Canon PIXMA MP970 InkJet Printer
Canon mp970 won't feed paper straight - Canon PIXMA MP970 InkJet Printer
SOURCE: Paper will not feed properly/one side of paper not feeding in straight
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 23, 2008
57 varieties
  • 1653 Answers
SOURCE: Canon MP970 how to remove print head to clear
Make sure the unit is powered off before continuing.
On the right hand side of the print head holder - just to the right of the print cartridges is a lever. If you raise this lever the print head can be removed. When you have cleaned off the debris carefully replace the head and then lock the lever in position. Then run nozzle check, cleaning cycle then a head alignment process before printing again.
Posted on Oct 01, 2009
Testimonial: "A very quick response that exactly solved my problem."
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Posted on Nov 10, 2009
  • 739 Answers
SOURCE: Canon Pixma MP470, paper feed not straight
Hi Dave
First thing to check is that the left hand paper guide (as you look at the printer from the front) is up tight against the edge of the paper stack in the feeder. I've seen many printers where (over the course of day to day use) the paper guide has progressively moved itself to the left so that the paper is not held at all. The pick-up for the paper is at the bottom right hand corner and if the guide is loose the paper can skew as it goes in - and then it only gets worse.
Another possibility (and this has just happened to me) is that the long piece of sponge that runs the length of the platen (you'll only see it if you open the top and shine a light in) has come adrift slightly. Mine actually came completely out after 2 or three skewed/crumpled sheets. I washed it, dried it out with kitchen towel and then carefully refitted it. Now the printer is running like a demon.
Let us know what your outcome is.
Posted on Dec 06, 2009
Geekman
  • 32281 Answers
SOURCE: my canon pixma mx320
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Posted on Jul 26, 2011
On plain paper the colours are about normal on photo paper to much red on the light colours I am using a canon mp970
You must change your paper quality. i.e. Plain Paper to Photo Glossy paper... it will help you... thanks
Sep 05, 2011 | Canon PIXMA MP970 InkJet Printer
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
I con not use my printer Canon MP970. There is 5100 error. I have no idea how to fix it and why it happens.
hi,
please browse the following
www.printerproblemsolved.co.uk/I have problems with paper feed and cannot seems to be able to sort it out, I would like to open .... my printer come up with a error code 5100 canon mp970 .
May 28, 2011 | Canon MP970 Photo All-In-One InkJet...
Paper will not feed on right hand side. Goes in crooked
the wheel is worn down. cheaper to get a new printer. you amy also have a small peice of paper wtuck. turn the printer around and take off the cover plate. look for msall paper jamed ont hat right side under the wheel.
Dec 04, 2009 | Canon MP970 Photo All-In-One InkJet...
How do I switch to the bottom paper tray, my top tray is feeding the paper through crooked, and I can't get my project printed
Look for a button that says "feed switch" each press changes from one tray to the other. usually a LED shows which one is selected.
Aug 12, 2009 | Canon MP970 Photo All-In-One InkJet...
MP970 won't take paper from rear tray
Replace the printer is the best suggestion unless this is a very high end unit.
May 19, 2017 | Canon MP970 Photo All-In-One InkJet...
No usb cord in box
this is straight from canon.com
dot.gif PIXMA MP970 All-In-One Printer dot.gif Power Cord dot.gif Print Head dot.gif Ink Tanks:
PGI-5 Black
CLI-8 (Black/Cyan/Magenta/Yellow/Photo Cyan/Photo Magenta) dot.gif Document Kit: Cross Sell Sheet
Easy Setup Instructions
Network Setup Guide
Quick Start Guide
Setup Software & User's Guide CD-ROM so it looks like you'll have to purchase a usb cord.
Mark
Apr 30, 2009 | Canon MP970 Photo All-In-One InkJet...
NEED PRINTABLE PDF FILE OF REPAIR MANUAL FOR CANON MP970
Here you go:
http://www.tradebit.com/filedetail.php/4981055-canon-pixma-mp970-printer-service-manual
Jan 27, 2009 | Canon MP970 Photo All-In-One InkJet...
Hi ... MP970 User
there is another answere the mp970 can go thew acleaning cycle but if it clicks and the paper can smere ink real easly it will probly have to be replaced.
Sep 02, 2008 | Canon MP970 Photo All-In-One InkJet...
Canon PIXMA MP970 InkJet Printer Logo
old marine
old marine
