Delta Electronics Power Supply DPS-980AB A - Office Equipment & Supplies
SOURCE: I HAVE 2 NETGEAR FS516 SWITCHES. BOTH NEED A NEW POWER SUPPLY.
Replace capacitor C3 47uf@25V. It will fix that ADP20KP 90% of the time.
Posted on Mar 24, 2009
simidoggy
SOURCE: DPS-210EP-2 power supply blew up
hi there the 8 pin ic in question is a Viper22a available from good electronic stores i got mine from
Cricklewood electronics for a couple of quid , also replace the capacitor c72 47uf
hope this helped
my board is DPS-210EP B REV 00
should be same
Posted on Jun 14, 2009
  • 123 Answers
SOURCE: TV will not come on at all-Westinghouse LTV27-W2
Are you sure it`s the power supply?? Has the LOT (Line Output Transistor) or LOPTX (Line Output Transformer) gone short circuit or failed?? Disconnect the set from the mains, disconnect the PSU (Power Supply Unit) from the set and perform a resistance check. The easiest way to do this is to remove any (if there is one) covers off the LOT case and check the resistance from the LOT Casing (Collector) to the metal chassis / the tuner casing or any other metal chassis connection. It should read quite high in one direction due to the efficiency diodes. If the LOPTX/LOT has failed, the reading will be quite low in both directions. Note!! The aerial socket may be isolated so don`t use that as an earth. Another tell tale point is to switch on the set and listen carefully to the PSU, If it`s tweeting or a high pitched whistle, there`s more than likely to be a short on the secondary side of the PSU (Decoupling caps inside the PSU casing) or as I said earlier, the LOT/LOPTX. To test the PSU, disconnect the line output stage and connect a mains powered light bulb to the 90 - 120 volt output lead of the PSU which feeds the LOT/LOPTX. You may need to keep the other leads connected to the set because some PSU`s are turned on by the sets remote control uPC. I hope I`ve not gone too technical for you, Ian
Posted on Jul 23, 2009
SOURCE: My DPS-730AB A power supply made by delta for my server quit
I need the diagram of the output pins of the source (DELTA ELETRONICS) Model: DPS-730 ABA
Posted on Sep 08, 2009
domotek
  • 591 Answers
SOURCE: hi... my "DPS-800GB A" power
Verify if the voltage switch is in the correct position (110V/220V) in the back of the unit, verify if the power cord is OK, plug it in a different AC outlet
Posted on Jan 04, 2011
How to power on dps-450cb?
http://www.ascendtech.us/delta-dps-450cb-a-450w-power-supply_i_cspdps450cbarps.aspx
Aug 29, 2014 | Apple Xserve Raid Delta Dps-450cb-1 L Rev...
How to turn on DPS1200ab power supply
get a power supply tester ($20) and if the ps is ok it will turn on when the tester is plugged in
Dec 11, 2012 | Delta Elec DPS-1200AB Power Supply Server...
No power at all
Check the capacitors in the power supply, check for any bulged tops. Your problem is most likely power supply related.
May 21, 2012 | Televison & Video
I need to build a psu for my sony vaio vgc m1 (18 pin motherboard connector) any1 know how to do this? or if any1 has a spare thanks
Make a Switching Mode Power Supply? (SMPS)
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Ummm, no.
Have it repaired by a competent tech would be one solution. Pretty hard to find, as most are just glorified parts changers.
Information to pass on to the tech:
I've been searching the internet, and it seems a the R20 resistor on the circuit board, (Don't know if it's on the input base plate, or the stabilization base plate), is one component that fails.
It is a .22 Ohm resistor.
(That's point 22 Ohm, not 22 Ohm)
A competent tech will know what voltage range, and tolerance range, to use for a replacement.
The second component that seems to fail is one, or all four, of the power MOS-FET's.
(IF I understand correctly, the 07N60C3 MOS-FET's, are Infineon SPP0760C3 unit's.
Again IF I understand correctly, the Hitachi 2SK3234 may be a replacement)
The power supply used was made by Delta Electronics. It was made in Japan. The model number is DPS-197AB.
Sony's Part Number is 1-468-878-11.
The pinout of the 18-pin ATX main power cable connector, (CN1), according to my sources is;
Pin 1 - Orange - +3.3 Volts
Pin 2 - Orange - +3.3 Volts
Pin 3 - Red - +5 Volts
Pin 4 - Blue - Power Signal
Pin 5 - Green - PS-ON (With ground power source on)
Pin 6 - White - Fan -(Motherboard fan)
Pin 7 - Pink - + of Mfan (Case fan. same/same)
Pin 8 - Yellow - +12 Volts
Pin 9 - Yellow - +12 Volts
Pin 10 - Black - Ground
Pin 11 - Black - GRD
Pin 12 - Black - GRD
Pin 13 - Black - GRD
Pin 14 - Purple - +5 VSB (+5 Volt Standby. The usual 5 Volts)
Pin 15 - Gray - Power Good
Pin 16 - Black - GRD
Pin 17 - Black - GRD
Pin 18 - Yellow - +12 Volts
The PSU (Power Supply Unit) case, indicates 197.7 Watts is the maximum rated amount.
1) The 3.3 Volt power rail can handle 8 Amps (26.4 Watts)
2) The 5 Volt power rail can handle 7 Amps (35 Watts)
3) The 12 Volt power rail can handle 14 Amps (168 Watts)
Total is more like 229.4 Watts.
(Of course this power supply, probably only has a maximum sustained efficiency of 80 percent)
To you:
Fact:
A computer only uses the power it needs, and NO more. If there was a way to hook up a 1000 Watt power supply, it wouldn't hurt the computer.
IMHO, a tech will not be able to substitute the circuit board, and components, out of another power supply, and be able to fit it in the power supply case, that fits in the Sony Vaio VGC M1 All-In-One computer.
The size, and shape of the metal casing, is a Proprietary item for the Vaio VGC M1, as well as the 18-pin ATX main power cable connector.
(As you are already aware about the 18-pin connector pinout)
(Proprietary meaning made for THAT computer)
This would mean using an external power supply. Something that a professional tech is not going to approach.
Liability issues dealing with safety.
IMHO though it is a feasible approach, IF, the power supply has a metal case cover of solid design, that allows a space between it, and the replacement power supply's case.
Power supply's cases have ventilation holes in them.
What do you suppose would happen if a toddler, inserted a metal rod down into one of those ventilation holes?
Bad shock to Fatal!
Also if water were accidentally spilled on the power supply.
There would have to be a metal casing that allows an air space between it, and the replacement power supply's case, so the replacement power supply would have adequate ventilation. Would also be a safety guard.
I have also searched online, and I also concur that the Delta DPS-197AB power supply, is as rare as hen's teeth.
(Chicken hens do not have teeth)
I did see where someone on Ebay UK had one for sale, but the listing is over.
I saw a Japanese auction website that had one also, but it's listing was over.
I also saw where a person on a forum had two for sale. (Long over with)
Indication was a bad power supply, but the final diagnosis revealed the motherboard was bad.
(Food for thought)
{I also saw where a motherboard was offered on Ebay}
To conclude:
MAYBE, there is a tech that will outfit an external power supply.
Not a very aesthetic approach, but a viable one. (IMHO)
The tech will remove the 18-pin connector from the power wires of the original power supply, and insert the power wires of the replacement power supply into the 18-pin ATX main power cable connector.
Or perhaps an individual will again offer the power supply
NOTE*
DO NOT open the power supply yourself!!
There are Electrolytic Capacitors used in the power supply. (Input Stage, and Output Stage. They are used as Filters)
An Electrolytic Capacitor slowly builds up a charge, then releases it, All At Once.
They can hold a charge, once removed from power, for weeks, months, and sometimes over a year.
IF, your finger's touch the terminals on the bottom of an Electrolytic Capacitor, the charge can be released to you!
IF, your finger's touch, and complete a circuit that one, or more capacitors are in, the charge can be released to you!
Bad shock to FATAL!
There is a proper way to discharge a capacitor.
I will not list it.
Repair is for a qualified, competent repair tech.
[ http://tokyoswan.web.fc2.com/4htm/delta/delta.htm
The above link, is to show you some of the Electrolytic Capacitors used inside a Delta DPS-197AB power supply.
The link is not translated on purpose.
Scroll down to the 3rd, and 4th photo. That large Black object that looks like a Can, and has - 4742AW on it, is an Electrolytic Capacitor.
This one has enough power stored to put X's in your eyes]
Jun 05, 2010 | Sony VAIO M1 (VGCM1) PC Desktop
32" TV no power.
This question has been answered:
http://www.fixya.com/support/t362706-westinghouse_lcd_tv_parts
it is Delta Electronics DPS-210EP-2 C power supply board
this company can repair: http://www.power-supply-repair.com/
Oct 24, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
hope this helped
should be same
Jun 12, 2009 | Westinghouse LTV-32w3 HD Television
Mar 21, 2009 | Delta Electronics DELTAELEC PLUG IN POWER...
Video card upgrade
Can you try your old card? does your card have a 6 pin connector on it for power? Does your power supply have a 6 pin connector for video card power?
Lou
Aug 28, 2008 | Sony VAIO VGC-RA810G PC Desktop
Is ther any power suply that i can use instead of my original one
Its physically different shape will probably require you to modify your case to accept a conventional power supply. Just did a quick search and found an Ebay active sale and an on-line store that had your power supply for a reasonable amount. That might be a more reasonable alternative for you. Ebay: http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&from=R10&satitle=power+supply+dps+185db&sacat=3666%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=14850&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1%26fsoo%3D1&coaction=compare&copagenum=1&coentrypage=search&fgtp= Other guy: http://affordablesurplus.com/delta-dps-185db-a-power-supply.asp
Dec 06, 2006 | IBM DPS-185DB (DPS185DB) Power Supply
118 people viewed this question
jasbo
jasbo
