Question about HP Hewlett Packard ALL-IN-ONE-TouchSmart IQ504t- Intel Core 2 Duo T5750 , 4GB DDR2, Intel Media A... PC Desktop
My HP 320-1030 touch smart stopped working why?
The computer does not turn on, the adapter is blinking but no current is going into the PC then the adapter stops blinking all together
dvrsetup
  • 43 Answers
SOURCE: need adapter connectfor an HP Photo Smart 35 mm slide scanner
The HP Photo Smart 35 is a USB printer. Your computer has USB ports. You can utilize an open USB port on your computer to connect the printer. What is a CS100-818035 plug?
Posted on Jan 18, 2009
SOURCE: Touch screen stopped working
Hi Everyone
I have the solution to the touch screen problem. You need to get the support and strip down document for yout touch screen from HP.. for instance the one for the tx1000 series is c00853874.pdf
you will need another machine or to print the pages required to strip your machine all the way down to removing the monitor, and the surround on the screen.
the document is step by step...label the screw etc, you'll be fine...even if you have never done it before.
the result is the terrible build quality of the machines. the ribbon access cables for the webcam, and for the touch screen are poorly installed.
I found that my touchs screen access cable was not actually properly installed at all, and was only barely contacting when i received the machine.
my touch screen is working properly, you need to be gently with everything, the circuit board that the webcam and the touch screen connect to is directly behind the screen..
you must strip the screen down, and then lift the glass... there are 4 screws around the edges of the glass when you have it stripped down... once you lift the screen up.. there is a circuit board on the rear of the top of the plastic screen back. the are connectors going into this...for the quick access buttons around the screen edges...the webcam,.. and the touchscreen.
i have to say i just discussed this with a guy called GINO on Hp online support...and he doesnt care that this is the solution...or that there has been a manufacturing fault since day on.. they never plugged the cables in properly.
email me if you get stuck...
James
Posted on Jan 22, 2009
Murphybanton
  • 2004 Answers
SOURCE: HP Pavilion dv8000 - touch scroll pad won't work
at the top black rim around the touch pad, there is an orange light showing, press and have it show blue. It will work now.
Cheers.
Please rate this fixya.
Posted on Apr 10, 2009
  • 121 Answers
SOURCE: My touch screen isnt working at all
it seems that your hardware is all right.you need to contact your retailer to get your screen repairs.
Posted on Jun 18, 2009
  • 280 Answers
SOURCE: hp laptop touchpad for cd and wireless conet. stopped working
I get it. The multimedia keys above the keyboard is not working. If I'm right, check if you have installed the HP Quick Launch buttons software. If not check in C:/SwSetup and you'll find a folder. Install the application and check if the buttons are working. If not, post back
Posted on Jun 24, 2009
How do i turn on a wirelss switch in a touch smart 300?
HP lists it as a function of the Touch Smart software.
Here is HP's setup guide:
HP Support document HP Support Center
Aug 19, 2014 | HP Pavilion Computers & Internet
My laptop will not charge when the charger is plugged in. I tried removing the battery and turning it on while it was plugged in. Is my computer messed up or is it just the charger. Also my warranty has...
Your laptop still not charge even with the battery removed?
I guess you need a new adapter. Or you can test with a known working adapter first.
Specification of HP pavilion DV7 charger:
Output: DC19V 4.74A
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin inside
Reference: http://www.chargerbuy.com/replacement-hp-pavilion-dv7-ac-adapter-19v-4-74a.html
Feb 16, 2011 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Problems with the ac smart adapter Hp Compaq 6910p
You could possibly have a loose dc jack.Being able to wiggle it around and getting it to work tells me that the jack is probally going out.That wiggling your doing can cause an arc on your system board,which can short out your board.Stop wiggling your power supply adapter in your dc jack and take your computer to certified repair shop and have your jack checked.Best to rule this out first ,so no damage is done to your board.If you jack test good ,then replace you power supply....Good luck
Apr 08, 2010 | HP Smart Buy- HP Compaq 6910p Notebook PC...
We have a HP 600-1030 computer. THere is an
yes you can go to hp touch smart open go to definitions and see display light and afther will see a rainbow in th e screen and is just touch the desired colour and that it thanks and good luck
Oct 27, 2009 | Computers & Internet
I have an hp touch smart pc laptop that is teathered to my phone for internet. my friend has a dell inspiron mini laptop and i was wondering if there was any way to share my internet with him
Linksy has a Router wireless-G 2.4 GHz with speed booster . hook it to your computer and use a wireless adapter in the dell . i have my PC and Laptop hooked up this way and it works great .
Sep 05, 2009 | HP TouchSmart IQ770 PC Desktop
Connecting laptop tip to auto adapter
you may look the jack(tip) show here:
1ecfef4.jpg 1) your car adapter, the red color wire is + pole which connect to the hole of jack(tip), the black wire is - pole which connet to outcover metal of the jack(tip). that is very common.
2) your new jack: check as smae as above. usually white color connect to red color, and black to black is ground connect to outcover of tip.
then you need check again the voltage pole, the tip 's hole should be possitive "+" and the outcover metal is negative "-" pole, it is very important.
hope help you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
May 28, 2009 | HP Compaq tc4400 Notebook
Wireless adapter is not working.
Go to the HP website and get the latest version of the driver for the wireless adapter. Then got to Start---->Control Panel--->Add/Remove programs and unistall the current driver. Then got to the System folder in the Control Panel. Go to the device manager tab and go down the list until you find network adapters. Left click the x beside the name and left click on the wireless and it should turn blue. Right click and choose uninstall. Then reboot the computer. If the device is still working the computer should find the "new hardware" as windows loads. Then when it asks for the device use the new driver to install it.
Apr 09, 2009 | HP Pavilion dv6000z Notebook
Activate Wireless netwerk connection HP Compaq 6710b
have hp computer,unable to switch on wireless connection.im just a novice.HELP
Jul 08, 2008 | HP Smart Buy Notebook
Remote internet access
RESTORE YOUR COMPUTER! This just happened to me and i looked up and tried EVERYTHING! Since my wifi button had only stopped working 2 days ago, I restored my computer to 4 days prior because I was told that sometimes without you even knowing you allow stuff to get on your computer whenever you get online which could cause your computer to turn functions off automatically. My wifi button actually stopped working after I went into a mcdonalds with my computer an used their wifi so I think me allowing their wifi onto my computer did something to it because when I took it home the button was just red altogether and it was SOOO frustrating. But as soom as I restored it, my computer came back on and a little window popped up saying "Your wifi is currently off, toggle your wifi key to turn it on/off". I was so happy! The simpliest thing that no one would ever think of.
May 23, 2008 | HP Pavilion dv1000 Notebook
HP Hewlett Packard ALL-IN-ONE-TouchSmart IQ504t- Intel Core 2 Duo T5750 , 4GB DDR2, Intel Media A... PC Desktop Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
