Question about Cambridge Soundworks CD-740 Clock Radio
Digital display on cd740 does not light fully
Digital display is very dim and cannot be seen
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
diy.stackexchange.com/.../lights-lowering-in-the-kitchen-when-turning-o...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
blog.1000bulbs.com/what-is-causing-my-house-lights-to-dim/
Dec 21, 2015 | Microwave Ovens
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
The display screen resets every 15 seconds When it does the lights also dim. This happens while driving and while idling in the driveway Any thoughts?
i have seen this sort of problem before and it was rectified by loosening the display surround , care fully ease the surround trim away ,use a wooden tongue depressora ,like the doctor presses your tongue with, you wont damage trim this way , the trim may pop off completely if so just push very gently back into position just enough so it clips in ,let me know if this helps
May 14, 2014 | 2008 Mazda MAZDA6
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
Apr 26, 2014 | Bose Wave Radio Am/fm Awr1-1w Remote...
Cambridge soundworks 740 display too dim
Mine is dim also. Apparently sending it in for repair is not an option.
Unfortunately, the CD740 radio has reached end of service life. Parts are no longer available & we cannot repair them. We apologize for any inconvenience. If you need further assistance, please call us at -800-367-4434, Monday - Friday 9AM to 6PM central time.
Best Regards,
Cambridge SoundWorks
Sales and Support
Aug 20, 2012 | Cambridge Soundworks CD-740 Clock Radio
I dropped my LG GT350 phone, it can be switched on and fully function, but the touch screen display is not showing. It can still be pressed and a dim blue back-light is on but nothing can be seen
The LCD screen may have been damanged, visit your celphone technician or phone provider to have it checked depending on the impact of how hard you dropped it, touch screen phones are very sensitive if you dropped it really bad the technitian may have to replace the screen.
Jul 07, 2011 | LG GT350 Cell Phone
Cannot connect in any way to router, all lights on.
access your router's web-based configuration page at http://192.168.1.1
Sep 04, 2009 | Linksys Wireless-G WRT54G Router
The digital display on my 2003 Toyotal Matrix is not visible. At times is can be seen dimly, but usually is just dark. Any solutions other than replacing?
it could be your dimmer switch for the dash lights i would have that checked first or replace it and if that don't do it then you will have to replace the dash
Aug 22, 2009 | 2003 Toyota Matrix
Oven digital lighted display is dim
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
Cambridge Soundworks CD-740 Clock Radio Logo
80 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
