Could be the laptop needs a driver installing for it to work.
Conventional bluetooth and wireless needs a 2-way signal so the item you want to connect will appear in the laptop wireless and bluetooth menus and you can click on it and enter a password or pin number.
If the headphones don't appear in the menus you won;t be able to connect them. In that case you should refer to the headphone instruction manual.
I have found that you need to turn off the Bluetooth and the phone or what you are trying to pair with before you pair this will give it a plane start and it should pair
vsidharth I had the same problem with my satio.. i fixed it,
what to do is pair your bh-503 then click on auto connect.. now click on bh-503 a menu pops up look for set unauthorised.. turn it on now turn off your ear phones and back on, your satio will say connect, and will now give you the option to enter your pair code 0000.. once you done that, your ready to go.. hope this helps
If your bluetooth is saying connected, but not paired, it means you need to pair the devices (generally with a four digit code typed on the host and then again on the client).
If you're laptop cannot see your device, it's because you have to make it "discoverable".
0000 is the pairing code to connect BlueTiger Delux BH-M20 to your cell phone. There's no pairing code required to connect it to WIndows 7, but it is likely that it will not show up under "Sound" devices, and there's probably nothing for that. I've tried about everything and I'm ready to get a Mac and throw all of my Windows laptops in the trash. $20k waisted on Windows.
dude on the device u want to pair. then go tu bluetooth connectivity menu of ur cell and go fr my devices. ter search fr ur device and add it ter.. ter u go ready to use...
for internet settings call hutch customer care,they will provide u settings in h/s, and after than activate bluetooth on your h/s and on laptop than pair u r devide ,than give dialing number than dial .than u can connect to internet
turn the bluetooth on wait 10 seconds after the bluetooth has turned on. after it has turned on hold the (+) & (-) volume buttons at the same time for about 5 seconds. the light on the outside will then start to flash green and red, and it is ready to pair to your phone.
blinking red and green means the headset is in pairing mode and ready to be connected to your phone. This means it is either the first time you have paired the headset or you have depressed the volume +/- buttons simultaneously for more than 5 seconds. If your phone cannot find the headset, it may be a compatibility issue. Try pairing the headset with a friends phone, possibly a sony ericsson. Good luck.
