I have a hannspree sn10e2 netbook and right when I press the power button the screen is white. It also doesn't turn on without being plugged in.
4 Suggested Answers
eng_darwish1
  • 233 Answers
SOURCE: White screen, Solid green light.
the control IC should be replaced
Posted on Jul 10, 2008
  • 732 Answers
SOURCE: Hannspree HF-289H LCD Monitor not displaying anything.
conor455, I am sorry to hear that your lc display has been struck down with the "BLACK screen of DEATH". Most likely the "switch-mode-power-supply/inverter supply" has failed!!! If your monitor is out of warranty then i suggest that you find your way to my fixya profile and read some of the responses I and others have already written about the BLACK screen symptom and what you can do to try and repair it!! YOUR DISPLAY IS SICK. The SMPS is in SHUTDOWN mode trying to save itself from further damage and or catastrophic nonrecoverable failure. eg. sparks, smoke, fire!! Leave your monitor OFF and do a little bit of research of BAD electrolytic filter capacitors and other stuff that causes LCD backlight's to fail to light-up. Conor, when you asked "ANYONE KNOW THE PROBLEM?" all I can say is visit YOUTUBE and search for and view some of the longer vid clips of "lcd monitor disassembly and/or lcd monitor repair to help YOU to make a decision as to the fate of your HF-289H. Bye for now. If this info has been of some use, please rate this response on fixya! 12fixlouie aka louie12fix
Posted on Nov 09, 2009
Testimonial: "Very helpful feedback 12fixlouie! Thanks for helping me diagnose the problem, I will now do research needed repair my poor sickly monitor."
budmrtn
  • 11361 Answers
SOURCE: Monitor Turns off without pressing the power button
You need to open it up and inspect the inside, the power supply section will be the first place to look, look for caps with leaking/bulging top.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jul 09, 2010
How to reinstall windows and all drivers
1. Go to applications screen and touch the settings button.
2. Touch the Backup & Reset option.
3. Select Factory data reset.
4. Leave the erase SD card option unticked and touch Reset tablet.
5. Touch erase everything.
6. The unit will now reset itself back to factory reset and any previous information/data will have
been permanently erased.
For further help and support with your device including how to
install software updates if available and much more:
http://www.hannspree.com/
Dec 29, 2013 | Hannspree HannsBook SN10E2 Atom N470...
Can't get my wireless on on my hanspree SN10E2
Fn+F9 for wireless on/off . Try the user manual :http://www.manualowl.com/m/Hannspree/SN10E2-8/Manual/221301
Feb 03, 2013 | Hannspree Computers & Internet
How to repair red screen on asus eee pc sea shell
Remove any discs in the computer.
Hold the power button down until the computer turns off.
Press the power button to turn the computer on. If this doesn't work, proceed to step four.
Remove the battery and unplug the netbook. Wait 30 seconds.
Reinstall the battery and plug in the netbook.
Press the power button for ten seconds. If this doesn't work, proceed to step 7.
Insert the end of a paperclip into the reset button to reset the netbook.
The reset button is a small hole that usually appears next to the USB and other ports.
Windows 7
Create a new Notepad file.
Type this code:
taskkill /F /IM dwm.exe
Save the file as displayfix.bat in the following location:
C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
Restart your computer.
hope this helps
Sep 25, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
NEED A DRIVER WEB CAM HANNSPREE SN10E2
I understand that you want to download a webcam driver to your laptop. There's a website where you can download webcam driver for free. Just click_here so that you will be directed to the exact site.
Once you are there on the site, just click on the "webcam" link for you download it for free, then just follow the prompts and you are good to go.
I hope you find it very helpful.
Aug 25, 2011 | Hannspree HannsBook SN10E22BU3221 Netbook
When I try to start io my netbook, it sounds as if the disk is going, like it does when it starts up normally, but the green processing light doesn light up and it starts to sounds as if the disk is...
1. turn off your netbook completely.
2. unplug the ac adapter and remove the battery
3. press the power button for about 5-10 secs
4. plug in the ac without the battery and turn on the system
-if still doesnt work unplug the power cable and press the power button for 5-10 secs
5. turn the netbook upside down
6. locate the memory door and reseat the memory
-make sure that the memory is properly installed from the slot
then put back the memory door and all the screw
7. restart the computer
Sep 06, 2010 | Acer Aspire One PC Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
