Question about Zanussi TD4112W Electric Dryer
My zanussi TD4112W tumble dryer has become very noisy when switched on and the drum is turning. Already checked to see if any objects are stuck within the dryer but nothing is evident. What can I do to solve the problem of the loud noise my dryer is now making?
4 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: zanussi td4112w drum stopped spinning
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Posted on Jun 19, 2009
apart4u
  • 213 Answers
SOURCE: just bought 2nd hand a supposedly good working
this could be the stats or the drum is not turning Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
  • 1525 Answers
SOURCE: tumble dryer TD 4112 W has power but drum does not
hello the first thing to check is. the long pin on the inside of the door these sometimes snap off . if ok then check to see if the belt has come or snaped if ok then you may need to check the capacitor this next to the motor will have 2 wires coming off it these dry up good luck
regards
shaun
Posted on Jan 17, 2010
How do I replace the front felt bearing on a zanussi tumble dryer?
The top and back panels have to come off. The belt taken off and the bowl removed from the machine. Lie the machine on its front. You can then see where the felts go. Some of them are held in with steel spring clips, early models are glued in onto the lip that supports the drum.
Jan 03, 2015 | Zanussi TD4112W Electric Dryer
Noisy dryer
I have had the same problem in the past, one thing you can check is the drum. See if it has any play by opening the door and see if you can push it up. it could be the felt strip is worn down or the rollers if it has any or the main bearing in the back. It is posible that is is one of the three things I said because they all cause noise. check it out i hope it helps you.
Feb 09, 2014 | Zanussi TD4112W Electric Dryer
Very noisey and rattles
check the spindle on the rear of drum. its positioned in the centre of drum
Jan 31, 2012 | Zanussi TD4112W Electric Dryer
I keep asking but dont get answers help please
There is a video here on how to replace a belt on a dryer. I have done this before and most dryers are the same. You have to take them apart. It is not a real easy job. Hope this helps. Scroll down to the bottom of page to see video.
http://www.espares.co.uk/part/tumble-dryers/zanussi/td4112w/p/1088/332/0/553236/501196/tumble-dryer-drive-belt.html
Dec 02, 2011 | Zanussi TD4112W Electric Dryer
Zanussi tumble dryer tds 280w front gasket snapped
it is the drum gasket that goes round the inner drum that forms a seal and acts as a buffer for the drum to ride on if not replaiced the dryer will get noisy and wear the drum out they are stuck on with a glue
Nov 06, 2011 | Dryers
No heat drum turns on td4212w
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 28, 2010 | Zanussi TD4112W Electric Dryer
Tumble dryer TD 4112 W has power but drum does not turn - light is on and it makes humming noise but won't start.
regards
shaun
Jan 17, 2010 | Zanussi TD4112W Electric Dryer
Just bought 2nd hand a supposedly good working order zanussi tumble dryer got it home turned it on drum turning but cold air in dryer. we then noticed that the back got rather hot.and then nothing. due to...
Jan 10, 2010 | Zanussi TD4112W Electric Dryer
Td4112 which way does belt fit around drive and
check the drive it should have grooves on it. that means that the belt grooves should go around the drive and facing the drum. When you see the belt on the drum you should not see the grooves on the belt
Dec 31, 2009 | Zanussi TD4112W Electric Dryer
Zanussi td4112w drum stopped spinning
Jun 19, 2009 | Zanussi TD4112W Electric Dryer
Zanussi TD4112W Electric Dryer Logo
49 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
