Question about Sharp R-1850A Convection/Microwave Oven
Sharp convection only runs for a minute - Sharp R-1850A Convection/Microwave Oven
3 Suggested Answers
SOURCE: Sharp Microwave/convection oven
We had the same problem, and the service technician quoted over $300 to fix it. My wife found this thread online (click on link below) and after following the advice here ours is now fixed for a total cost of under $40, and that included a new soldering iron (see below)!
http://www.fixya.com/support/t902145-sharp_r1870
The problem is either the damper motor or the damper switch. You can order both from Tritronics and ours shipped un less than a week. It is not possible to tell which it is without disassembling the microwave, so I ordered both. In our case it was the switch (one of the electrical contacts was black like it had burned out).
Read all the advice about discharging the capacitor; I would recommend downloading and printing out the service manual (especially page 18 which is an exploded parts diagram which helps you identify what is what (click on link below)
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
Page 14 is also useful because it gives you the part numbers to order from Tritronics. The two items you may need are 1-11 Damper switch and 1-22 Damper motor.
The space is rather tight, and you need to be very careful you don't cut your hand on the sharp (no pun intended) metal. It definitely helps to remove the long mounting bolts that runs through the space. Be very careful when disconnecting the electrical connections: the little metals tabs they use on the ends of the wires break very easily - hence the soldering iron. The most difficult piece is undoing the screw on the right hand side that secures the motor; it's just cramped and you need a very small/short phillips screwdriver to get to it. I would advise removing the switch first (it's secured by a couple of little metal tabs) because then the cam which drives the damper door will be able to drop free when you remove the motor. Finally, when installing the new motor, make sure that the tab on the cam wheel is correctly inserted into the little slot on the bottom of the damper door.
As I said above, read all the advice on the other thread and the general advice on working around microwaves on the http://www.microwavedisplay.com/ web site. It's all good stuff. Good luck!
Posted on Dec 23, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp convection microwave R-1870 runs about one
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Dec 18, 2010
Sharp convection microwave temperature is off on the convection side.
this is the thermistor is time to replace,if the fan of the oven is working,also couse this problem.
Jul 13, 2017 | Sharp R-9H84B Microwave Oven
When I run the my Sharp convection oven in the convection mode...it runs for about 5 min. at a time ..then stops....as soon as I hit start again it will run for another 5 minutes and shut down again. It....
Don't waste your money on unnecessary sources and unwanted repairs. Get this manual online under $10-15 and get complete guide on whether to repair or not, service it, and how to repair etc
Best Manuals
Mar 05, 2018 | Sharp R-930AK Convection/Microwave Oven
Convection starts ok, but quits after 10 minutes. It's 11 years old
Trying to calibrate mu sharp 32LE700UN. Settings are as follows:'
OPC is off, baklight at +14, contrast +30, brightness +2, color +2, Tone 0, sharpness 0, CMS Hue +12. Are there any settings I am missing or need to change to get the best picture? Also, color temp at middle and AV Mode at Standard.
Dec 16, 2009 | Sharp R-930AK Convection/Microwave Oven
Microwave/convection oven in our fifth wheel will not run past 59 seconds. For example trying to reheat a cup of coffee set at two minutes - it will only run for 59 seconds. I am afraid to try the...
looks like the timer brain has packed up on you,,
how old is it,, it may be cheeper to just replace the microwave as there not very pricy now,,there is very little inside them that you could fix your self, however,, putting your hand inside the back could kill you? so dont try it, play safe buy a new microwave insted
Oct 26, 2009 | Sharp R-1870 Convection/Microwave Oven
On convection or convection/microwave it runs for
Here is a link to your manual that you can copy and paste in your internet address bar;
http://www.nodevice.com/manual/newmans/upsharp/R303CWPDF/get52699.html
or
www.curtisint.com/html/custservice/.../SUN_SMW5500_EN.PDF
Oct 10, 2009 | Sharp R-303CW Convection / Microwave Oven
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Convection oven stops every 5 minutes and won't continue
to trouble shoot hold the door securely shut for longer than 5 min to see if it runs longer if it does the you should replace the interlock devise
Dec 25, 2008 | Sharp R-930AK Convection/Microwave Oven
Sharp R-9H66C Microwave Convection blowing fuses
check high voltage transformer and high voltage diodes, condencer, and magnetron.,
Oct 27, 2007 | Sharp R-963 Convection/Microwave Oven
Sharp R-1850A Convection/Microwave Oven Logo
22 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
