Question about Watches
How to change alarm time on Coss watch wr30m - Watches
SOURCE: Changing the DAY on this analog watch.
Turning it backwards didn't work on my watch. I ended up winding the time ahead several days worth to show the right day of the week (being careful to turn it to the correct 9 o'clock of the day, for me is was the first for morning.) Then I could go ahead and change the date using the first click postition of the stem.
I see that light bulb going off and you whispering "why, of course!"
Posted on Apr 03, 2008
SOURCE: Setting Time and Date on a Timex WR30M
1) Press and hold mode for about 2 seconds and then release. You will now be in the alarm edit mode.
2) Press mode once more and now you are in time edit mode.
3) Use the stop button to select what to edit, i.e. hour minute, etc.
4) Use the reset button to make the changes once you have selected the hour/minute, etc. that you want to change.
5) Press
Posted on Nov 18, 2008
gemineye61
  • 831 Answers
SOURCE: how do I set the time on My watch WR30M
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Posted on Jul 23, 2010
SOURCE: Can't turn off alarm
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
Posted on Nov 17, 2010
  • 1139 Answers
SOURCE: I have a WR30M watch
Follow these steps to adjust the time :
Step 1. Press and hold MODE for 2 seconds and then release. The watch will be in alarm mode.
Step 2. Press mode again to enter time mode adjust.
Step 3. Press the stop button to cycle through what you want to adjust.
Step 4. Press the reset button to adjust the actual item.
Step 5. Press MODE to exit time setting mode.
Hope this helps
Posted on Nov 24, 2010
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
Dec 13, 2017 | Timex Watches
How to set alarm in wr30m?
Try Googling (brand)(wr30m)(manual) without parens to get instructions.
Feb 20, 2017 | Watches
How can i change the day for the alarm in wr30m
it hangs on about the tip of clock it is
Sep 27, 2016 | The Watches
How to set the time on a wr30m watch
google how to set time on a wr30m watch
Sep 10, 2016 | The Watches
Turning off alarm on Model: WR30M?
Google (fossil)(WR30M)(manual) without parens for instructions.
Apr 05, 2014 | Fossil Watches
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
HOW DO YOU TURN OF THE ALARM ON THE GOLA WR30M
If its the 4 button watch, you hold in the bottom right, which sets it to alarm, and then press the top right button. It bleeps at each press and turns on/off the alarm display.
Aug 27, 2010 | Timex 1440 Sports Stealth 174 Wristwatch
Hope this helps.
May 05, 2009 | Watches
5) Press
Mar 07, 2008 | Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
