I have west point washing machine model 5260 e but it's not spinning very well, I need to know how to Spain manually ??.
Westpoint 5260 e
jumptrout51
  • 3361 Answers
SOURCE: Roper Washer Wont Spin Out
Probably a bad lid switch. Open the control panel. Disconnect the lid switch wire connector on top of the cabinet under the control panel. Make a small insulated jumper wire and insert it into the wire that is still connected to the control panel. Set the timer to spin. If it spins replace the lid switch in the cabinet. If not, replace the timer.
Posted on May 05, 2009
SOURCE: Classixx 6 1200 Express washing machine manual
whay may nero 9 serial number it das not working? ma old S.N invalid
Posted on Nov 01, 2009
  • 1937 Answers
SOURCE: My Kenmore Elite top loading washing machine won't spin or drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Dec 07, 2009
  • 3 Answers
SOURCE: Washing Machine CDA CI392 Model Manual needed
if you goto www.cda.eu you can download 1 from their
Posted on Mar 15, 2010
jsrock516
  • 5911 Answers
SOURCE: why my whirlpool washing machine wont spin model # LXR5432KQ0
If this is a Whirlpool manufactured TOP LOADER washing machine, a no spin problem can have several causes. Most commonly, this is caused by either a lid switch malfunction or a broken motor coupling. The following link explains how you can diagnose the problem and repair it yourself:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
Read through the link provided and let me know if you have any questions. I have included parts resources and instructions on how to replace each part as well.
The part number for a replacement lid switch is 3949247. The motor coupling part number is 285753A.
If you have questions, please post back and let me know. I hope you find this information helpful.
Posted on Apr 14, 2010
Manual for washing machine westpoint WMC 61013 Er
Try Googling (westpoint)(WMC 61013 Er)(manual) without parens.
Aug 06, 2017 | Washing Machines
Want to know what is the problem Westpoint WMG-71210 Washing Machine Symptom E07
Reset Buttons for Washing Machines
I have looked everywhere for an answer! Is this a U>K> model? Also if you have a manual that came with washer, towards the back it should give You the symptom/error codes meanings!
Apr 03, 2017 | Washing Machines
Manual for West point Bread maker 1138. "Need belts for motor part no." 2 belts
user manual
http://documents.mx/documents/wpbm-1138-westpoint-horizontal-25lb-125kg-bread-maker-by-hi-fi-wpbm1138-56114ce4cb1e3.html
only belt part listed online
Related Products only
Jan 17, 2017 | Kitchen Appliances - Others
My westpoint machine model WMC-5260 SERIES DOES NOT WORK WELL. IT IS AS IF THE TEHRMOSTAT HAS FAULT. where can i find a maintainance engr in nigeria?
Sorry. I doubt anyone on this forum could give you that information. It's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in telephone directories OR stay on line and search for 'westpoint washer service' for instance or 'westpoint washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
Good luck,
John C
Mar 04, 2011 | Washing Machines
I want the manual of WESTPOINT WMB-50T
I have big problem my washig machine is a top loading Westpoint brand, model : wtw-700 its drain well but can't spin at all please help .
Sep 30, 2010 | Washing Machines
Cant find west point
You can try looking for a Westpoint service specialist in your area at
http://www.servicemagic.com/emc.Air-Conditioning-directory.-12002.html
If you cannot find a service specialist who can help you, please post your zip code.
Thanks for using fixya!
BelgianAlien
Feb 24, 2009 | Computers & Internet
WESTPOINT TV CODE FOR REMOTE
get a motorola cable box and connect it to it and your problem will be solved, because that brand seem to be gone for ever.
Nov 30, 2008 | Microwave Ovens
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
