Question about Proform Crosswalk 480 Treadmill Walking Belt
Walking belt is slipping - Proform Crosswalk 480 Treadmill Walking Belt
3 Suggested Answers
  • 43 Answers
SOURCE: Belt stops when i walk on it
with item going 2mph, stand on foot rails, hold on handles,with one foot try stopping walking belt-look at front roller while doing this-if walking belt slips around frt roller, its the walking belt loose. at each corner there is an adjustment,with proper allen wrench, turn CLOCK WISE one turn EQAULLY on each side!! Then recheck,keep doing this untill it quits slipping-Small moves is best don't crank.
Now on other hand if walking belt Stops with frt roller, its the MTR dr. belt under the hood, to tighten,with 2 9/16th wrenchs, I loosen mtr mount bolt,with one hand apply pressure to mtr, retighten, or have wife apply this pressure with her foot,but don't over tightn-u want to turn belt 1/4-1/2 inch on side. Also check walking lube under walking belt!!
Posted on Jan 07, 2010
maxtreadmill
  • 832 Answers
SOURCE: when walking on my pro form xp weight loss 620,
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Posted on Jul 20, 2010
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Mar 25, 2011 | Nordic Track NordicTrack A2550 PRO...
My belt keep slipping. And I try tighten the ajustment bolts.
Make sure you adjust vthe motor belt first, it may be where the slipping is coming from. You should only be able to twist a properly tightened motor belt 45 degrees. After that, readjust the walk belt. If you have been tightening the walk belt trying to get the slipping out it may be too tight now. Use the instructions in your owners manual to adjust the walk belt. Also, lube under walk belt with the recommended lubrication . That will help the walk belt not too grab and take pressue off of both belts. Good luck
Mar 15, 2011 | Horizon Exercise & Fitness
The belt is tight why does it still slip
Hello, If the walk belt is tight, you will want to remove the motor hood and watch that the drive belt and motor are staying at the correct speed when the walk belt slips. The most likley cause is the front drive pully on the front roller. This sometimes looses adheshion with the front roller and slips, usually when you are running. After it gets reallt bad it will slip when walked on.
Hope this helps.
Feb 03, 2011 | Cadence Weslo 927 Treadmill Walking Belt
When walking on my pro form xp weight loss 620, while walking along fine, every so often it starts to make a slipping sound and seems like the belt is slipping. tried tightening the belt and still does the...
Jul 07, 2010 | Proform XP Weight Loss 620 Treadmill
Belt is slipping,
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill running belt adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
Jul 06, 2010 | Life Fitness 9000 Next Generation...
Belt is slipping when i walk on it
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 17, 2010 | Icon Image 17.5 S Treadmill
Belt is slipping
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 15, 2010 | RTO Image 15.0R Treadmill Walking Belt
Reebok 8050es treadmill walking belt has started slipping/skipping. It has been oiled and it is 2 years old.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
May 05, 2010 | Reebok 8050 ES Treadmill
My treadmill walking belt has moved to the right and slips.
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, Start unit @ 1.0 mph using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn to move belt to the right. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise or clock wise 1/2 of a turn depends on the tension that will be on the belt take your time and walk on it to feel the belt underneath you2_bing.gif Repeat until the walking belt is centered.
Feb 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
Jan 06, 2010 | Proform 760 CrossTrainer Treadmill
Proform Crosswalk 480 Treadmill Walking Belt Logo
21 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
