Question about Boating
How do I check my tilt&trim fluid in my 225 yamha out board
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 36 Answers
Tilt the motor all the way up and put on the tilt lock. The resorvoir on the trim unit will have a 17mm or 18mm head on the plug. Pull the plug and fill with fluid until it runs out of the hole. Reinstall plug and your done. DO NOT over tighten the plug b/c it will pull the theads out of the reservoir.
Posted on Jun 22, 2014
4 Suggested Answers
  • 3 Answers
SOURCE: Volvo-penta aq271c, trim will go down, but not up.no pwr at relay
First check the switch-- does it have power, then check the solenoid to see if it works-- there are two. One is for down, One is for up. If you get power from the solenoid-- outgoing-- check connections going to pump motor.
Posted on May 17, 2009
  • 5 Answers
SOURCE: tilt-trim not tilting down after being tilted all the way up
check the solinoid you should have two,one for up and one for down,you can test by putting a screwdriver on both neg and pos contacts at same time,if thats not it check to make sure nothing came unpluged
Posted on Jul 26, 2009
canbruce75
  • 1776 Answers
SOURCE: how to service a tilt/trim on a 50 hp yamaha
To check the fluid level, tilt the motor up and engage the tilt lock lever. Open the bolt on top of the tilt/trim reservoir. The fluid should be even with the bottom of the bolt hole. If not add some fluid. When you put the bolt back in, run the trim up and down a few times. That should purge any air out of the system. Always be on the lookout for any leaking hoses or fittings. Hope this helped and best wishes.
Posted on Aug 31, 2009
Have evinrude 225 etec and the hydraulic tilt will not tilt motor all the way up
Hey Hunter,
First, make sure the manual release screw is seated tight.(port side of engine mount) ..Does the pump run and just not lift? Does the motor jump and jerk while you are trying to trim up? Can you lift the engine by hand while you are trimming? Have you filled the fluid reservoir with fluid? - There is a cap with a slot on the reservoir - MAKE SURE the engine if at full tilt - fill the reservoir.. you can use Dexron type III transmission fluid.... check these items and reply to me.
Jul 02, 2017 | Boating
My johnson 50 when in the up position it slowy goes down and there no oil leaks ps how much tilt fluid should be in it tilt cheers michael
Have a bad check valve somewhere in the system allowing pressure to bleed backwards through the system, should be able to hear it when the bucket is up in the air turn off the tractor and listen closely to the lines for a slight whining sound from the fluid leaking when it should be sealed
Oct 11, 2016 | Sierra Johnson/Evinrude Tilt and Trim Pump...
Will low fluid level cause power trim/ tilt go not hold position
Low fluid level will cause it to fail to actuate and not go up or down, can also let it not hold position as well. Filling to proper leevel with specified lubricant is recommended. If you allow the level to go too low, the pump will pull air and could burn out.
Sep 21, 2014 | Yamaha Tilt Trim Motor, 40-90 HP Outboards...
Check fluid in tilt &trim in a 225 yahama out boarb motor
Usually, if you have trim tilt issues its because the seals on your trim ram(s) are failing and youre losing fluid. Prolonged issues with leaking seals make it more worth while to replace the unit, rather than spending the money to fix seals and whatever else has since corroded or failed. That being said, there is a plug, typically a phillips head or flat head, at the bottom of the trim pump, that is where you can drain or fill the fluid. VERY IMPORTANT!!! Have the motor trimmed completely up and have the trim locks holding motor up before opening plug, you can easily kill yourself or others if that motor were to lower very suddenly. Also, this procedure is best followed step by step with the manual. Skipping a step will leave air in the system and could potentially allow the motor to kick up while running, or not stay trimmed up. Unless mechanically inclined, take to a mechanic, it will save you money, time and grief. Hope this helps, feel free to ask more about this if needed.
Feb 09, 2014 | Boating
Evinrude 50 HP outboard tilt and trim
sounds like the motor has give out . the clicking is probably the relays
Jun 14, 2013 | Boating
The trim/tilt on my 97 Johnson 150 outboard is not moving. Tilt motor runs. Some time ago my mechanic told me not to run the tilt all the way to the top, which is, I think, what happened. Any ideas on...
Make sure there is not a spring loaded locking lift latch engauged. If there is you will see a little movement and then the motor will sound slower. If there is no movement and the motor runs the same speed with no change you are low on hydraulic tilt and trim fluid.
Please take a moment and rate my answer............ Thanks
Nov 28, 2010 | Sierra International 18-6756 Marine Power...
Amplifier cutts out when I hit my tilt trim button on my boat
Check all the speaker wire connections because the stereos will go into protection mode if you're losing or causing an unwanted grounding.. even on the speaker connections..
Apr 22, 2010 | Boating
How to service a tilt/trim on a 50 hp yamaha outboard. I think the fluid is low as the trim will leak back down after raising the engine.
Aug 31, 2009 | Boating
My 1978 140 evinrude electric trim tilt motor working but wont lift or lower happend suddenly after it lifted.maybe the pump?
First make sure you are not in transit mode. Some outboards have a lever which keeps the motor tilted for trailering. You should have a fuse for the tilt motor, check that. If the pump is turning and it sounds like it is whining you are pushing air and either lost your hydraulic fluid or have an air bubble in the system. Check your fluid reservoir.
Jun 06, 2009 | Boating
Where do i put in hydraulic fluid in a johnson 225 boat motor
if its an outboard you will see a reservoir near the cylinder on back, be careful and set the shallow drive lever so the weight is off the hydros when you open it, there can be up to 3000psi if it has weight/pressure on it
once added you have to blead air bubbles, go up then down at least 10 times
also a boat parts store(phone book) may be able to help you
Jan 02, 2009 | Plumbing
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
