Question about Blenders
Bearing on blades on vm0103 are locked down
The blades won't turn on the blender container. Bearing is locked.
SOURCE: Blades won't turn
If the problem is that the blades are jammed and you can't turn them manually, you can let it sit ( and dry out ) for a few days, or you can try adding some oil. I had the same problem and this worked. My problem now is that the blades don't reach to where the motor is turning, so even if they're not jammed the don't turn. If anyone knows and answer to this I'd appreciate it.
Posted on Feb 12, 2008
cactus bob
  • 267 Answers
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 24, 2009
  • 7 Answers
SOURCE: Jack Lalane Health Master 100 Bearing for Blade
We no longer offer the Jack Lalanne Health Master Blender or offer support for it. For Warranty, Service or Parts, Please call the Manufacturer- Tristar at 973-575-5400 ext 129
Posted on Jun 30, 2009
Treefrog15
  • 127 Answers
SOURCE: Mx91 Dynamic Blender Bearing failure
Since the blender costs over $600, yes.
Posted on Jul 10, 2009
SOURCE: ninja blender blade wont turn with food in container.
Blades don't turn worked fine since last Xmas not even a year old yet...anybody know the solution
Posted on Sep 29, 2012
Ninja blender 1100single server sticks after using hard to loosen
I experienced the blades freezing on a different blender after making smoothies and letting the unit sit for some time. The problem was sugar seeping into bearing interface and solidifying. I soaked the blade assembly in water and they freed up.
I now add water to blender container after each use and operate it until clear water seeps out the bottom of the bearing.
Oct 24, 2014 | NINJA Kitchen System 1100 - As Seen On...
Vitamix 3600 throws sparks when turned on
Sounds like it may need a new blade/bearing assembly or coupling or both.
Feb 25, 2014 | Vitamix Blenders
Can you repack the blade bearing on Vitamix Blenders?
On the Vitamix blender models we have here in NZ it is not possible to repack the bearings, you just purchase a new blade assembly complete with bearings and the driving clutch.
Nov 11, 2013 | Vitamix Super 5000 Work Top Blender
Vitamix TNC 60 oz container leaks when in use. how to replace seal and or bearings?
If it is not the HUGE blade retaining ring under the beaker a bit loose then you will be buying new parts to repair it. The only other possibilities are beaker cracked and leaking (new beaker) or bearings & seals worn (new blade & bearing assembly)
Oct 21, 2013 | Vitamix 5000 Work Top Blender
ELECTRICAL SMELL AND SOUNDS ROUGH
It sounds like you need to replace blade & bearing assembly in the beaker, change it before you wreck the motor.
Aug 23, 2012 | Vitamix 5000 Work Top Blender
Burning smell in the container and outside when in use
Seal under blade Assembly, on shaft leaks, allows liquid to enter bearing, which then fails, creates heat and overheats rubber, thus the smell. Bearing and seal must be replaced.
Jul 11, 2012 | Breville BBL600XL. 5-Speed Blender
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
Loose blade.
mcdevito75 here, It could be a sealed bearing in the motor you here, Check online with Bosh Blender .com, contact them. Or see an appliance repair shop in yout area, if it is a bearing in the motor, a replacement blender may be your best bet.
Jul 10, 2010 | Bosch DHMUZ4MX2 Blender
Our wet container smoked and smelled, the taste of plastic got in the shake..There is no "visible" trouble Do you think it could be just the agitator or do you think it could be the motor Model 5000
first take off the container and on the under side bottom of it that sits in the unit is a drive gear see if you can turn it with your fingers also at the bottom of the wet container inside it is a blade that spins in a bearing and this bearing gets tight or even seized up at times strip out this bearing and renew it and the seal but watch your fingers as the blade is very sharp rap it in a thick rag to hold it in your fingers,,,,
Jun 06, 2010 | Vitamix 5000 Work Top Blender
Osterizer blender problem
Is the black plastic part, seal, and glass portion snugly fitted together? If so, it's likely that the black plastic part isn't making contact with the pin. On mine I have to turn it about a quarter turn to lock it to the motor/ drive pin.
If I have a hard object such as ice cubes too firmed placed in the blender against the blade and the glass, I shake the container to loosen the materials and reseat it onto the drive pin as mentioned above.
May 09, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
Blenders Logo
42 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
