Question about Bosch Water Heaters
Bosch logixx 8 e34 - Bosch Water Heaters
Could anyone tell me what the Error Code E34 is referring please? Thanks
Maybe. Knowing what it is that is generating error code E34 would be good start. Need manufacturer and model number.
Oct 21, 2015 | Water Heaters
What does error codes e34 and d65 mean on ariston boilers
You need to service the boiler and more likely to remove the restriction ring in flue, as only serving not always work or work only for short period, as boiler get older it is struggle to move exhaust gases out from burning chamber so it need good clean for fan, heat exchange , and there is restriction ring just befor L bow which need to remove so gases can flow better.
Jan 16, 2012 | Water Heaters
No hot water
Before calling service technician, open following link for Bosch troubleshooting resources including Bosch contact number and possible manual:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Tankless water heaters require yearly maintenance to check gas pressure, inspect and clean burner and combustion parts, inspect vent and vent drain, clean air filter, check water flow, de-lime the heat exchanger etc.
This maintenance can stop ordinary problems from occurring, and can be done by the homeowner by reading Bosch service manuals for specific model number.
The continual maintenance, and cost of repairs and parts, and cost of professional service are more expensive than expected $1-8 monthly energy savings from owning tankless.
Fix most tankless problems yourself, same day, for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 12, 2011 | Bosch 425HN NG Tankless Water Heater
Gas outdoor mounted AQ250 won't stay lit. Unit is about 2 years old and has been working great.
Before calling service technician, open following link for Bosch troubleshooting resources.
Sample manual has troubleshoot section and yearly maintenance requirement.
http://waterheatertimer.org/pdf/Bosch-250SXO.pdf
Service bulletins for 250SXO
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXOTechSupport/ServiceBulletins/tabid/573/Default.aspx
Tankless require yearly maintenance as outlined in manual.
No tankless manufacturer suggests do-it-yourself repairs on their product, in part for liability and danger to customers, but for long-term customer satisfaction.
Repairs and yearly maintenance will eliminate the $1-8 monthly energy savings expected from owning tankless.
Apr 19, 2011 | Bosch AquaStar 2400ES-NG
What is the difference between Bosch GL4 Ariston and Bosch GL4Ti Pro Ariston?
The difference between the Bosch GL4 and GL4Ti is the GL4Ti has a glass lined tank with titanium inside and an 8 year warranty. The GL4 has a glass lined stainless steel tank and a 6 year warranty.
Sep 02, 2009 | Bosch GL4Ti Ariston Pro Ti Electric...
Ariston ACO MFFI 35 E34 fault code present
This is the manual for your boiler. I hope the information contained in the manual will help you identify your problem.
http://www.ariston.co.uk/uploads/doc47e92b04013d8.pdf
Mar 30, 2009 | Water Heaters
Connecting a AE9.5
I would use # 8-2-with ground to have positive grounding at device , not 8-3 witch is more costly , also copper only no aluminum
Jan 31, 2009 | Bosch PowerStar AE9.5 AE9.5 Point-of-Use...
Water Heaters Logo
48 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
