Question about Ingersoll Rand SS3J5.5GH Wb Ir Portable Air Compressor 5.5HP Honda Gasoline Engine Single Stage 8 Gal Twin k Wheelbarrow
Dies when pressure kicks back on
Engine runs fine but some times when running the engine shuts off when the pressure gets low and the pump kicks in then motor dies. the hole thing has very low hours on it but I don't use it to offten
2 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: I have an Ingersoll Rand
When the compressor comes up to pressure and kicks off, you should normally hear a gasp of air escaping. That gasp is the release of pressure from the compressor itself - not the tank, and it is supposed to get released so that the compressor can restart without being preloaded with compressed air. My guess is that the gasp is not happening. It is probably some debris or a gummy mechanism. The mechanism is supposed to be triggered by the same mechanism that shuts off the motor.
Posted on Aug 30, 2010
05 tahoe oil pressure shut off car
Were there any engine noises such as a lifter tick? If it were mine I'd be installing a manual oil pressure gauge to verify what the oil pump is up to. There were issues with the oil pump pickup screen o-ring. Either way, it should be looked into.
Mar 24, 2014 | 2005 Chevrolet Tahoe
Pump runs and runs
You can take the cover off the switch and turn the small nut counterclockwise to lower your high setting, as turning the large one, will change both high and low settings, and this may take care of your problem for now. If you have a indoor pump, the pump may be worn and having a hard time getting up to pressure, or a foot valve plugging up, or small hole in the pipe going into well.
Jan 04, 2014 | Goulds Pumps Goulds J5S Jet Pump Shallow...
My 1998 dodge neon wont start until i pour gas in the throttle body then dies out when i press the gas
What is the fuel pressure when the engine is running ?
Has the filter been replaced ?
Aug 16, 2012 | 1998 Dodge Neon
I have a 2003 explorer sport. It starts up fine when it's cold, but if the temp is above 90, once I shut down it wont start back up. It will turn over , but quikly dies out even when pressing down on...
you have low fuel pressure for some reason, pump may be going or fuel pressure regualtor on fuel rail is bad.
pressure should be 43 psi, key on , engine off. and 34 with engine running.
Try this to confirm low pressure. Turn key to on and listen carefully for the pump to hum for 5 seconds. When it shuts off, turn key off. wait 30 seconds or until you hear relay click under dash. then turm key on for 5 seconds. repeat one more time. Then try to start engine. If it starts right up, pressure was low.
What you did was prime the system and built up pressure before start.
The pump only runs for 5 seconds when you turn key to ON, unless the engine starts. Then it stays on.
report results. please rate answer
Jul 29, 2011 | Ford Explorer Sport Cars & Trucks
1988 Ford Bronco ll---I've experianced several times a problem with the engine just shutting down at any given time while driving. Had a mechanic tell me he replaced a fuel switch somewhere under the...
The Bronco has TWO fuel pumps, a low pressure and a high pressure. Low pressure is located in the fuel tank, the high pressure is located....Attached to the LH frame rail ahead of the fuel reservoir.
my guest would be the high pressure pump is getting hot and shutting off, cooled down and starts back up again ??
Jul 14, 2011 | 1988 Ford Bronco II
Grundfos JPF4A pump. takes a long time to get up to prime then once it kicks in after running water it gets to 50 shuts of but drop pressure instantaneously and kicks back in again. The constant on off...
The check valve is bad. When the system builds up pressure and shuts off the check valve prevents water from dropping back down the well line. When the check valve goes bad water drops back down the well line and siphons water back out of the well tank causing the switch to kick on and off constantly. The check valve will between on the well line coming from the drop pipe. It may be making a constant rattling noise as pump is running. Replace the check valve and you should be fine. Also check the pressure in bladder tank it should be 2psi below the "cut-in" pressure for the switch.
RJ
May 22, 2011 | Grundfos Plumbing
The Warning Light Comes on "Stop Engine Low Oil Pressure" what does this mean
car needs oil pressure or bearings will wear out in short time. Do not drive or start engine with this light on. Might only be pressure sending unit. Can replace sending unit and start briefly to see if problem resolves. If light still stays on, shut off engine and have oil pump replaced.
Sep 06, 2010 | 2005 Volkswagen Passat
Will start then dies
On the regals they have a ceramic resistor on the passanger side under the fender. It heats up and over time it tends to brake and the wire inside tends to rust away. The fuel pumps run in 2 different speeds. Had the same problem. Dealer only part yet the car would run and you would think it was the fuel pump. Turn the key it kicks on then start and dies out. Ceramic on the pass side would need replaced. It is white about 2-3 inches long or so held on with 2 bolts i do believe. Ill find a bulliten i found online to help me diagnos the problem. :) hopefully this helps someone out instead of spendin $$$ that ya cant afford with the recession eh?
Mar 07, 2009 | 1998 Buick Century
Motor shuts down
Have you checked/tested the fuel pressure? sounds like a bad pump and or plugged fuel filter, check the pressure, if it is low replace the filter, if that still doesn't help you will need a new fuel pump, it is located in the fuel tank.
Aug 15, 2008 | 1999 Chevrolet Blazer
Engine dies
My wifes vehicle did that for about a year in hot weather also.
It was giving PCV valve codes, misfire coded, but finally after her insisting I was wrong, I replaced the fuel pump and fuel filter and it has been running fine ever since.
it would run great when it was cool, then when the outside temp rose into the 80s and 90s it would run about 30-40 minutes and just shut down. Let is set, it would run another half hour or so.
Yeah I understand your frustration, its hard to determine also , even with a gauge by the time you get things disconnected and hooked up, it checks out fine.
Jul 20, 2008 | 1999 Buick Regal
Ingersoll Rand  SS3J5.5GH Wb Ir Portable Air Compressor 5.5HP Honda Gasoline Engine Single Stage 8 Gal Twin k Wheelbarrow  Logo
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
