Question about Cameras
How to set date on polaroid is425 - Cameras
Polaroid i830 remove date stamp
Hit Menu, scroll right to Date Stamp and set it to OFF.
Also, could try in the user guide: polaroid.com/support_detail?p=4031
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Feb 13, 2012 | Polaroid i830 Digital Camera
How to change date and time for Polaroid i531
Press the menu button, scroll sideways (press lightening icon) to Setup (tools icon), then down (disp) to highlight date and time. Press Set or the lightening icon to select the date and time setting, then press disp or the opposite upper part of the rocker to change the numbers, and the lightening or flower to move between the various date and time settings. Press Set when you are through.
If you leave the battery out of the camera for 48 hours, you will be invited to set the date and time at the next switch on.
You can download a manual for a similar camera, the i1036, at polaroid.com, but there does not seem to be a manual for this specific camera there. Try THIS LINK
Dec 05, 2010 | Polaroid i531 Digital Camera
We have am i634 polaroid digital camera and some
couldnt find the manual for that camera but im sure the polaroids are kinda the same. this is what another camera manual said
From the Record menu,
select Date Stamp.
2. Use the or keys to go through the selection.
3. Press the OK button to save and apply changes
Apr 15, 2010 | Polaroid Cameras
Polaroid a520 will not keep the date
You may want to set the factory defaults by going into the main maenu.
Nov 22, 2009 | Polaroid a520M Digital Camera
How do i set the date on my polaroid i735
This is straight from the "Polariod i735" Manual.
"• Setting Date/Time, Display On/Off
Date and time can be displayed on the picture by the following steps:
1. Set the camera to Still Image mode.
2. Press the button.
3. Press or button to select (Date Stamp).
Date StampOffDateDate & Time
4. Press and button to select the desired setting."
For the full PDF manual go here:http://www.google.com/search?q=polaroid+i735&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7ACEW_enUS345US345
Hope this helps!
Sep 29, 2009 | Polaroid Cameras
Setting Date/Time on Polaroid a530
I contacted Polaroid help desk and they were clueless. They said there is no way to set the time after messing around with the camera for 10 minutes.
When you pull the photos off the camera it does record a date and time. I believe they forgot to add the option in the setup menu so you cannot get to it. I asked for them to send me a differant camera and the help desk rep laughed.
I guess thats what I get for buying a cheap camera.
Sep 12, 2009 | Polaroid A530 Digital Camera
Date & Time will not stay current
same thing happened to me too! lol. However after you press the menu button and click "default setting", go set your date and time again. Then turn the camera off. Turn it back on and you will find that the date/time is correct!
Jan 03, 2009 | Polaroid i1035 Digital Camera
Time and date
There is a small 3volt battery soldered on the main board that needs to be replaced. It has a yellow band around it, unless you can replace it yourself it's not worthwhile. If you decide to replace it beware of the flash capacitor charge.
AL
Sep 17, 2007 | Polaroid A500 Digital Camera
Polaroid pdc 4055
Take batteries out- leave for an hours or more re insert batteries and follow set up procedure in the manual
May 12, 2007 | Polaroid PhotoMax PDC 4055 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
