Question about EXPOBAR Office Pulser Espresso Machine
Expobar leaking steam - EXPOBAR Office Pulser Espresso Machine
  • 7 Answers
Where is it leaking steam from? If it is from the porta-filter, you need to replace the group head gasket, which is done with something like a screwdriver to get it out.
Posted on Sep 13, 2014
Hissing vent and steam coming out of back upper area of machine can I fix it myself
Hi... It sounds like something may/could have become disconnected. I wouldn't hesitate to take the back off... the problem should 'in this case' be obvious.
May 17, 2014 | EXPOBAR Brewtus Espresso Machine
Expobar espresso steamer not working
The copper pipe the steam comes out of may be twisted it happened to mine.
Nov 30, 2012 | EXPOBAR Coffee Makers & Espresso Machines
Expobar steam wand loss of pressure
Are you leaving enough time for the water to heat up to a sufficient temperature? Typically 20 minutes is needed to ensure good steam flow.
May 25, 2012 | EXPOBAR Office Control Espresso Machine
I have a brewtus lll-V (9 months old). yesterday, it began emitting a constant sound of hissing steam from the top/rear of the machine, with occasional belches of an airy popping sound, that registered...
That sounds more like a safety valve issue than the vent valve, that is poping because of too much pressure, try lowering the pressure stat on the machine, or replacing it.
Jan 02, 2011 | EXPOBAR Brewtus Espresso Machine
Safety valve cn10 keeps activating about 10 seconds after switch on. any ideas anyone. stafco markus 2 group semi auto
Try this open the steam wand and leave on when turning the machine on, when valve stats hissing with steam close. If that works then the vent valve needs to be replaced, If it blows out hot steam from valve then the pressure stat is not operating properly.
Jun 22, 2010 | EXPOBAR Office Control Espresso Machine
How can I increase the pressure for the steam wand?
If boiler pressure is set to about 1.2 bar on machine and you are getting no steam then check the nozzle on the steam wand, that might be blocked, before adjusting the pressure stat in the machine.
May 31, 2010 | EXPOBAR Brewtus II Redesign
I wish to lower the steam pressure slightly how do I do it. Many thanks
Inside the machine their is a presurestat which is connected with a pipe to the boiler and inside the pressurestat their is an electrical contactor which turn on and of the heating element. this pressurestat have an adjusting screw on the top which have he signs + and - if you turn it to - then you will reduce the presure insite the boiler. However the normal pressure should be between 1.2-1.3 bars.
Dec 04, 2009 | EXPOBAR Brewtus II Redesign
Expobar espresso machine not siphoning water
sounds like a leak..check the lines water may have shorted it out!
Dec 09, 2008 | EXPOBAR Office Control Espresso Machine
Machine working but not brewing coffee
Hi mate, Check the water - in pipe to ensure there is no blockages/. also check up around the group head to ensures old coffee ground have not been left there and gone hard.
Jul 31, 2007 | EXPOBAR Office Pulser Espresso Machine
EXPOBAR Office Pulser Espresso Machine Logo
Top EXPOBAR Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you an EXPOBAR Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
