Question about Carrier 38BRC048 Air Conditioner
I have a 6 wire ferance with a black wire being hooked to the c termal and the hunter t-stat 44133 does not have a c termal so were do i put the black wire
Rheem Heat Pump Thermostat Replacement (#41-20804-15)
you need a 2 stage heat and cool t-stat hunter t-stat is not 2 stage
Feb 19, 2013 | Heating & Cooling
Changed honeywell T8400C 1024 to Hunter 44760, I have five wires white, red, yelliow, green, blue. Hunter Thermostat reads "NO A/C Power.
On the t-stat and the furnace make sure the wires are hooked like this...
Red to R
White to W
Green to G
Yellow to Y
Blue to C
then it should work..
Thermostat Wiring and Terminal Designations
heatman101
Jun 12, 2011 | Heating & Cooling
I HAVE A HONEYWELL THERMOSTAT THAT HAS BROKEN. IT HAS 7 WIRES. G-GREEN C-BLUE R-RED Y-YELLOW L-BLACK W2/E-WHITE O-ORANGE ITS ELECTRIC WITH NO BATTERY. I BROUGHT A HUNTER THERMOSTAT WITH BATTERY. ALL IT HAS...
Shut power off to Air Handler first before hooking up the thermostat..... Looks like the Hunter Thermostat does not have a Common Terminal...... Is it a Heat Pump thermostat???? I am not a big Fan of Hunter Thermostats they do not have the features that Honeywell thermostats have.
Back to your Question:
G to G ; R to Rc&Rh : O to Y/O; White Wire to W/B; Y to Y1;
L-Black is not used it was for a service lite
C-Blue will not be used it was the common wire
With the Hunter Stat you will not have an emergercy heat option
May 24, 2011 | Heating & Cooling
I pulled off my old thermostat and didnt label my wires, and I'm attempting to hook up a hunter thermostat #40170, I have 4 wires coming out the wall
What you have to do is identify your power which is usually red. once you know what that is tap one of the other wires to that then see what comes on Fan,A/C Heat. Once you hit the wire to the Red mark them then hook it up. Also you can try going to the furnace and seeing what colors are hooked up there then do the same at the t- stat. If this help please rate me or do a testimonial.
May 23, 2011 | Hunter Heating & Cooling
Cannot get Hunter stat 44155c that is connected to a Rheem 1210b to shut off after the stat reaches the set temp. How is an original 7 wire connected to the Hunter stat?
y is to condensor contactor wire
c is common
r is power
w/w1 heat strips
o/b reversing valve
e/w2/aux heat strip also
g is blower
For a rheem unit, make sure reversing vavle is set for "B" not O.
Blower may run for up to 120 seconds after shut off. My experience with hunter stats are not good (even out of box). Recommend honeywell tsat.
Apr 05, 2011 | Heating & Cooling
Old Gas furnace(heat only)
Yes, it only needs 2 wires to run.
Please rate Fixya solutions
Jan 20, 2009 | Hunter Fan Company 5/1/1 Programmable...
I am having difficulty wiring my hunter ceiling fan
For the fan alone, you hook the black wire from the fan to the black wire in your electrical box; white to white. If there is a red wire it's for the light, hook it to the black wire from the box. If you let us know what wires are available in your box and what's coming out of the fan and whether the fan has a light and whether the box is wired for separate lighting, we could go a long way towards solving your problem in more definitive terms. Hunter is a premium fan, their package directions are good.
Dec 30, 2008 | Hunter 52" Ceiling Fan With Light And...
Wireing code from goodman heat and air to a Hunter 44360 programa
To get your heat going take the red wire hook it up to R on t-stat. Take white wire and hook it to W on t-stat. Take the green wire and hook it to G on t-stat. that will get you heat. Now I need for you to go to the unit where the wires hook to the furnace circuit board. I need to know what color wires go to what on the board. Might have to take off bottom panel. should only be using 4 or 5 wires. Get back with me and will complete the wiring. Be sure no wires at the t-stat are touching each other as this will short out transformer. So tape them off or cut flush so wire and insulation are flush. ken
Dec 11, 2008 | Goodman CLQ36AR49 Air Conditioner
Carrier 38BRC048 Air Conditioner Logo
15 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
