Question about Nordic Track NordicTrack - Commercial 2450
System will not start. Says BAD SD CARD. Where is SD CARD?
The SD card 512mb has been working fine about 3 years,then the camera started taking only blank photos. What can I do?
SD cards can fail. # years on a SD card may be all you'll get. Try another card to see if you can record pictures on it. If so, then the card has gone bad. If not , then the camera needs a repair shop.
Jun 18, 2015 | Konica Revio KD-200Z Digital Camera
Forgot my memory card pasword
To format your SD card you need the following SD card, SD memory card adapter, SD card reader on your P.C. first insert the memory card into card adapter, insert the adapter into the P.C, click start>my computer> Secure Digital (SD) card and then navigate into the folder named system folder, open the sub-folder MMCstore and you should be able to see your password and recover it, If you want to reset your password you should just format SD card by clicking start> right click on my computer and select manage> Disk management > go to your SD card, right click on it and select format and then start format.
Jan 10, 2013 | SanDisk 4GB microSDHC Memory Card
My micro sd 1gb was formatted but the card appeared to have 0kb space available, what should i do/
The most common thing that causes these problems is that an Incorrect format was done on the disk. Here are two different ways that you can fix these errors. I will give you the step by step way to fix them on each one.
First Way To Fix Your Issue:
  1. Stick the SD Card back into the Card Reader on your Laptop or Desktop Device.
  2. Open My Computer.
  3. Right Click on the SD Card.
  4. Select Format.
  5. Format window pops up.
  6. Under the Drop Down Menu of File System Select NTFS.
  7. Then Click Format Wait till it finishes.
  8. Then you should be done and the problem fixed
Second Way To Fix Your Issue:
  1. Stick the SD Card Back into your Phone or Camera.
  2. Select the System Settings on the device.
  3. Select format SD Card on your device.
  4. This should fix the issue.
If you are still having problems with this card then the SD Card is probably bad and needs to be replaced.
Apr 23, 2011 | SanDisk 1GB microSD Memory Card
Iam using lexar 2gb micro sd card and it is showing some bad sectors how to repair and recover the data in the micro sd card
Hi:
You might try formatting the card. Go to the drive and rigth click on properties and then click on tools, first try error checking the drive, a box should pop up that has two options 1. Automatically fix the system errors and 2. Scan for and attempt to recovery of bad sectors select both boxes then click start. If all goes well and windows is able to repair the device then your data is saved. If not them reformating the device is the only way to restore the device, but data on the device will be lost..
Jun 29, 2010 | Electronics - Others
My mini sd card is in raw format and my computer can't read it - how do i change it back to fat file system ?
  1. Place the mini-SD card within the mini-to-SD card adapter. Make sure the tab on the mini-SD is facing the upper side of the adapter. Slide it in slowly, being careful not to damage the pins.
  2. Slide the adapter in an SD slot on your computer. If you do not have an SD slot, place the adapter in a USB card reader, and plug that into a USB slot on your computer. Give the computer time to read the card.
  3. Open "My Computer" (usually located in your start menu) and navigate to your mini-SD card. It will usually be recognized as a drive such as "E:" or "H:."
  4. Right-click on the drive and select the "Format" option. A menu window will open.
  5. Make sure that the drive size is set correctly, and that it is set to the file system you wish to use (usually FAT32 on an SD card). If you don't know what file system you should use, just leave it at the default setting.
  6. Enter a volume label, which is the name for the drive, then press start. This process should only take a few minutes.
WARNING
  • Do not use the "Quick Format" option unless you have just recently formatted the mini-SD card. "Quick Format" doesn't completely erase all data and is not effective unless used after a full format.
  • When you format your mini-SD card, all of the data on it will be erased. Make sure to back up your files on the card before formatting
Sep 25, 2009 | Electronics - Others
I have a Nokia 500 gps system. The sd card with
Try to fix the sd card with some recovery software (recuva or similar) and transfer the data to a new card. If you have the installation disk, use that to copy the data to a new card. Do not use the corrupted card, since you might lock up the device for good.
Jul 14, 2009 | GPS
Missing pictures
Lets check the SD card first.
Take out the SD card and put it in external card reader connected to computer.
Copy/transfer all the photos from the SD card to computer.
goto My Computer and right-click the 'Removable Disk' (the SD card drive) and click Properties.
click Tools and click Error checking - Check now button
select the option 'automatically fix file-system errors' and click Start button.
if any errors was found and fixed, you can also Format the SD card. And your SD card should not drop photos again.
Now put SD card back in the camera.
Now take 20 test photos and check if something is missing.
if not take 20 more test photos and check if something is missing.
if all is ok then you can delete all test photos and start taking normal photos.
May 31, 2009 | HP Photosmart R817 Digital Camera
Lost of space on micro SD card
Yes you can get your space back.
Let me clear you first you lost the space due to while system is writing data in your SD micro card it is suddenly ejected or disabled.
You will do this method to retrieve you data back. You will need some things
1. Card reader for SD micro memory.
2. A software called D M comes as Hard disk tool it comes in bootable cds.
You will remove your H D for safe side to protect your hard disk data.
Put your SD card in card reader and start you computer with bootable cd that contains D M software.
When your system is boot from cd run D M and go to option in D M erase all data. This will retrieve your all space from SD. Remember you can do the same thing with Hard disk if there is any bad sector or some space not avalible or disk partion is not able to delete by any softwares.
Hope this will help you, If you have any problem regards this you can reply to me other wise don't forget to make ansewer my thread.
Regards
nidostyle
Nov 17, 2008 | Microsoft Windows XP Professional for PC
Sdio GPS
as far as I know the e750 supports the SD-Card I/O standard. You can check your system seettings, go to START - SETTINGS - SYSTEM - SYSTEM INFORMATION - DRIVERS There should be seen the SD/MMC Host driver, the SD/MMC Memory Driver and CF Card driver. Also if the gps card needs a driver, it should be installed also! Perhaps a system reset helps you in the end!
Sep 08, 2005 | Toshiba e750 Pocket PC
Nordic Track NordicTrack - Commercial 2450 Logo
46 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
