Question about Maytag MVWC200XW Centennial 27" Top-Load Washer With 3.4 Cu. Ft. Capac
Tub banging against sides on spin
When washer entered spin cycle the tub started to bang against the sides of the machine. it was hitting so hard you could see it bulge out.
SOURCE: the tub in my washer likes to beat up against the sides of the machine during spin cycle
i beleive your problem is a worn Snubber ring it about $4.30
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1055142&PPStack=1
you should be able to get it at any appliance parts dealer
Posted on Nov 20, 2007
t1m130
  • 86 Answers
SOURCE: The machine does not spin properly. The tub
it sounds like the unit is not sitting on level ground sometimes there are feet that can be adjusted to raise and lower the unit on the front left and right side go to a department store and by a level for a couple of dollars and put it on the top exterior of the unit and check it left to right and front to back
Posted on Mar 14, 2009
  • 14 Answers
SOURCE: noise during spin cycle
check the counter balance weight
Posted on Jul 26, 2009
MalKontent68
  • 748 Answers
SOURCE: My Maytag goes out of balance and bangs loudly
This is usually due to the floor not being perfectly level, and as a consequence the washing machine not standing firmly on all 4 supports.
There should be at least 2 adjustable feet under the machine, try to make it stand as level as possible, with uniform load on all four.
If you have a bubble level it may help you establish, if there's an obvious slope on your floor and adjust the machine so that it's well levelled.
Posted on Oct 30, 2009
  • 401 Answers
SOURCE: maytag performa washer during spin cycle tub is
This sounds like the transmission is going. Better get another washing machine other than a Performa.
Posted on Jan 03, 2010
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
The tub moves to freely and bangs on the washer sides
The tub shouldn't bang on the inside of the washer cabinet, as you already know. That is not a "normal" way for it to fail. Rather, I suspect something else. First try this: If you have your washer right next to your dryer, the washer itself is probably banging against the dryer during specific times during the wash - but most likely during the spin cycle. If you spread them apart a little bit - or stuff a towel or two between them, you may find that it stops banging. The washer may also be hitting something other the dry, too. Check all around the washer - try to keep and inch or two between it and anything else. If it still is banging - then something else is causing it.
Jun 10, 2011 | Maytag Washing Machines
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
When washer goes into spin cycle it starts to tub starts to bang against side walls and shortly after error out, with an error on electronic display. Kenmore Elite Oasis
either unit is unlevel or one of the tub supports has come disconnected .... these washers have a slanted top lid so you must put level at side of washer on front and both sides and check front to back with level at side cabine seam as your leveling point
Jan 24, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Maytag Neptune tl- about 6 years old. Wont finish out the final spin cycle on any setting and also sounds like tub/drum is hitting against side of machine. It also rocks like crazy. Shows the code for...
You have a Clutch malfunction common problem with the FAV6800A and FAV9800A TL's. Owners very seldom report all the conditions of wild tub swings. You are on the ball with info feedback.
See if this post Clutch Fix will get you started.
Post back if you have questions or need help.........Rich
Jul 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
Maytag HAV4657EWW tub bangs during spin
This washing machine has self-leveling rear legs. Tilt the machine up on the front legs and you'll hear the back legs drop down to re-level itself. Center the basket and restart.
Mar 10, 2009 | Maytag MAT13MN Top Load Washer
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag MVWC200XW Centennial 27" Top-Load Washer With 3.4 Cu. Ft. Capac Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
