Morris wdw 60811, How many degrees is the "cold wash"?
I have 2005 saturn vue the windows want go down. Is there fuse for this that may need to be replace?
There is PWR WDW circuit breaker 30 amp in the under hood fuse / relay box . This powers the windows through the PWR /WDW relay in same under hood fuse / relay box . I would think the relay would be bad before the circuit breaker . Hope this helps you out , good luck
Apr 25, 2016 | Saturn Cars & Trucks
Where is the fuse for the FRONT passenger side power window for a 2009 Hyundai Sonata?
Check all possible fuses first a fuse is cheaper then a window motor
Jun 14, 2015 | 2009 Hyundai Sonata
The water is cold on the 40 degree wash (programme 4). It gets hot on the 60 and 90 degree washes, so the hot fill valve is working (changed it for a new one). I can't find a service manual for...
Whirlpool AWZ 410 Service Manual
The manual is not redundant. In other words it shows the cold info and not the hot. However if you look at the entire manual it shows both functions and starting on page 10 shows the hot wash sequence of events.
Nov 20, 2017 | Whirlpool AWZ410 Front Load Washer/Dryer
Water too hot
Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well.
Jul 20, 2011 | Washing Machines
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
Error code F20
The F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Newer washers sense and control the incoming water temperature. If you select cold wash and cold rinse you may think that it will not ask for hot water so you don't need it hooked up but you can't do that on this washer.
Even on a cold wash the temperature sensor will read the temperature of the incoming water. If your cold water is 60 degrees then the control will sense this and it may cycle the hot water on to bring the temperature up to 70 degrees.
Jan 11, 2011 | Whirlpool WFW9400S
FP Hot water used when cold selected
YOU NEED TO CHECK THE WATER TEMPERATURE AFTER THE TUB IS FILLED WITH WATER WHEN COLD IS SELECTED. NEW MACHINES WILL USE BOTH THE HOT AND COLD WATER VALVES TO FILL THE MACHINE. THEY DO NOT WANT YOU WASHING WITH STRICTLY COLD WATER AS THE DETERGENT WILL NOT PROPERLY DISOLVE. COLD WASH TEMP SHOULD AVERAGE 65-70 DEGREES.
Mar 30, 2009 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
