Question about Vans Flyaway Mens 9.5 Switch X Step-in Snowboard Boots
Ratchet strap replacement - Vans Flyaway Mens 9.5 Switch X Step-in Snowboard Boots
2014 bmw 1200rt rear suspension went solid when pulled down with straps it freed of is it safe to ride? thank you for any info.
Why did you ratchet it down till it was hard you only need to ratchet it down enough to stop it moving around
if it returned to the normal height after releasing the straps and when you sit on it and bounce on the seat and it compresses and rebounds ok it should be safe to ride
I have had my gs strapped down multiple times with no I'll effects
Jul 03, 2017 | BMW Cars & Trucks
Replace fuel tank straps
Here's a link on your gas tank.
Jun 24, 2013 | 1999 Ford Contour
1999 gmc envoy fule tank strap broke
use a nylon strap with ratchet latch
Feb 17, 2013 | 1999 GMC Envoy
Tilting the Engine
Set the parking brake and then put the shifter in neutral so you will not damage the transmission. Remove both upper engine mounts, They make a special tool for this but its a little expensive so I just use a ratchet strap. Hook one end to the engine and the other to something solid on the front of the engine compartment. Pull the strap as tight as you can and then ratchet the engine forward as much as you can. It won't give you enough room to remove the alternator, but it will help give you room to take off what you need to to get it out.
Jan 09, 2013 | 1999 Pontiac Montana
Outback Bike Rack Side Straps?
use your own or get strap / webbing and buckles from any upholstery retailer
Aug 20, 2017 | Cycling
My daughter has K2 Debut snowboard bindings which are REALLY hard for her to put on, and especially release. Even I have a hard time. It seems like the black strap with the teeth is just a bit too wide...
Try changing the black straps. You can get them in almost every Sports shop. Just take one off the ratchets with you and try out the different sizes they have.
Good Luck
Apr 18, 2011 | K2 Cinch Cts Snowboard Binding
How do you adjust the memory anatomoic fit ******** the boot of the Roller Derby Spartan Z-9-9 mens inline skate?
You have to lock the silver tab all the way back (it will click and lay flat). You have to keep that down with your thumb. There are two black plastic levers which hold the ratchet strap in place. You have to press them down towards the boot (not together towards the strap). When they are new this is a bit difficult. You may have to do one side at a time (just remember to keep the metal tab in its laid back position or it will snap shut and you will have to start all over again). Once you have the lever stop checks above the ratchet bevels of the strap, you will be able to pull the strap back out. Open and close the strap a few times to get the "new" out of it and it will function fine.
Jan 02, 2011 | Roller Derby Mens Spartan 9.9 InLine...
The easiest way to remove a fuel pump off a camaro
Drive the rear of the Camaro onto a set of ramps and secure the parking brake. If the Camaro no longer runs due to the fuel pump, place the rear end of the vehicle onto jack stands.
Use a socket and ratchet to disconnect the negative battery cable from the negative battery terminal. This removes power from the electric fuel pump.
Place a jack under the gas tank and raise the jack so it butts up against the tank. This applies pressure to the tank and prevents it from falling while you remove the retaining bolts for the tank straps.
Use a socket and ratchet to remove the retaining bolt from each of the two straps located closest to the rear of the vehicle. These are the rear strap bolts. Pull the straps down.
Lower the jack to lower the tank from the vehicle. Because you left the front of the straps attached, the tank rests at an angle under the vehicle. This prevents the need to unhook all of the hoses connected to the tank.
Place the cam tool (J-24187) onto the retaining cam on the top of the tank and turn it a quarter turn counterclockwise. Take the sending unit cam off the tank.
Disconnect the fuel pump from the sending unit cam and plug the new pump into the sending unit.
Place the fuel sending unit cam onto the tank and turn it clockwise a quarter turn with the specialized tool.
Use the straps, bolts, socket and ratchet to jack the tank back up under the Camaro and secure it.
Use the socket and ratchet to reconnect the negative battery cable to the negative battery terminal.
I hope the above helps.
Good luck.
Dec 03, 2010 | 1995 Chevrolet Camaro
How i change rear spark pluge on chevy uplander
have problem with my uplander the problem is the cylinder 2 iis misfire how can i fix it
Aug 29, 2010 | 2006 Chevrolet Uplander
Plastic strap broke
No plastic straps are usually not covered by warrenty. If you live next to a ski resort with a shop im sure they will have a replacement for about 10 buck MAX. Otherwise check at your sporting goods stores(I know scheels carrys them).
Mar 24, 2009 | All Star Bent Metal Biscuit ++ Snowboard...
Vans Flyaway Mens 9.5 Switch X Step-in Snowboard Boots Logo
93 people viewed this question
Top Vans Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Vans Winter Sport Expert? Answer questions, earn points and help others
