Question about Ovens
Tappan tm9050s Tappan 9050s died despite little use in 5 yrs on a boat. Can it be salvaged? No signs of life despite all the simple maneuvers. Thanks!
  • 833 Answers
SOURCE: tappan oven won't turn on after cleaning
I don't precisely understand...responding. I assume that if you say oven on that the oven isn't heating but the indicator controls are working. This has several possibilities. First, do turn your circuit breakers off then on...there are two linked together. This may reset something. If that fails, your problems are likely in either the high limit safety switch or the heating elements. The elements are more likely. To check them, turn off the power and remove them from the oven. This is usually by taking out one screw and unclipping the element. See if the element is bulged or damaged. If not, use a multitester to see if one of them is not conducting. Replace it. High limit should conduct fully. Use the curcuit diagram on the stove to determine its location.
Posted on Dec 28, 2007
SOURCE: problem with tappan wall mounted oven
yes, the problem is fixed thanks to repairclinic.com. those guys are awesome and there is no fee for their help. the repair parts are cheaper than anywhere else i've checked and the tech support is second to none.
Posted on Oct 12, 2008
SOURCE: Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Posted on Oct 30, 2008
  • 715 Answers
SOURCE: My Tappan gas stove will not heat up. The burners
thermo couple
Posted on Oct 08, 2009
  • 2468 Answers
SOURCE: what does -f-5 mean for the tappan electric oven.
it means the electronic control unit is defective
Posted on May 23, 2010
Seal on Tappan wall oven came off, what to do?
Hey friend, I appreciate your post!
I understand that seal on your Tappan wall oven has come off. In order to provide you additional information regarding the seal I would need your model number and serial number. You can locate the serial tag (which has your model number listed) on the front of the oven on the left side. With that information I could provide you additional assistance. I look forward to your response. -Matt
Aug 03, 2014 | Tappan Ovens
Tappan oven will not get hot
Assuming there is power to your appliance and the oven control is operating correctly, likely causes are a failure of the thermostat or heating element, both of these are easily checkable with a circuit tester or multimeter, and both are easily replaced. If there is some age to the appliance you may also want to inspect the wiring connections. Cooking appliances are very simple animals, they mostly fail through poor hygiene, poor maintenance, or corrosion caused by the products of combustion.
Feb 02, 2012 | Tappan 30IN ELEC IGNa Oven
How do light an old Tappan gas range?
If it has a pilot light: themobilian_411.jpga little gas comes out all the time on these. Just use a lighter. Warning for propane model have plenty of ventilation before attempting to light it. Propane is twice as heavy as air and nat gas is lighter than air. propane puddles and lingers while nat gas dissipates. If yours has a glow bar no need to light it:
Dec 11, 2010 | Tappan Ovens
My `70's Tappan wall unit is not igniting. The pilot is lit, but when the knob is turned, nothing lights, even turning the knob to broil.
Probably the safety valve is stuck closed or the bi-metal inside has died. You could try cleaning the probe on the pilot assembly and repositioning it so more flame can hit or clean the buildup around the pilot to make it a little hotter. When replacing the safety valve it will not be preset. Sit it beside the old one and get the orifice height the same and you will be in the ballpark of where you want that flame. More Here
Aug 15, 2010 | Tappan Ovens
Tappan range error codr f5
Hello,error code f5 means temp too hot Replace oven temperature sensor
Thanks
May 26, 2010 | Tappan 30IN ELEC IGNa Oven
What does an F3 code mean on a Tappan oven/electric range? The lock on the oven door is sticking out not allowing me to shut the oven door all the way.
This is your oven temperature sensor on your Tappan Oven.
T
hese codes are designed to troubleshoot your appliances and prevent further electronic issues from happening to your unit.
It is a simple repair that you can repair yourself and you can save a ton of money, also!
Once this part has been replaced, you oven should close properly and work just fine.
Oct 19, 2009 | Tappan 30IN ELEC IGNa Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
