Question about Jenn-Air Pro-Style JFC2089H French Door Refrigerator
LEVELING ISSUE No instruction on leveling. Can you adjust the rear wheels? Fridge leans left. In need to raise both rear and front on left side. I see the front adjustment. Is there a rear?
    Master:
  • Jenn-Air Master
  • 676 Answers
Http://jennair.com/digitalassets/JFC2089WEM/Use%20and%20Care_EN.pdf On page 2 are the instructions for installation.
Posted on Feb 14, 2014
I want to move my fridge but it's locked in place. How to unlock?
Hello Tina;
My name is Peter. I am a retired field service refrigeration technician.
You did not post your model number which is located on a label on the inside liner wall of your fresh food section.
First remove the bottom grill or toe plate in front of your refrigerator. This plastic piece is either held on with one screw at each end or pop out clips. If clips pull the plate straight out about 2" from each end. This plate is easier to remove with both doors open.
Refrigerator Leveling Screws: Most refrigerators have two leveling screws in the front, one on each side. These screws are for leveling the refrigerator from rolling on the wheels. Turn these screws counter clockwise.
Refrigerator Wheel Locks: Some refrigerators have a lever bar on the outside of the front wheels to lock the wheels in place.
Refrigerator Independent Wheel adjustment Screws: Some refrigerators have two hex head screws on each side. They raise and lower both the front and back wheels.
Mar 04, 2016 | Refrigerators
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
Feb 12, 2016 | Kenmore Refrigerators
How do I level my domestic kelvinator fridge . the floor seems to be level . I recently relocated to Cairns
the front feet under the door opening are adjustable screws. You may have to use a shifter to get them to move as they mat be rusted . adjust so the fridge slopes slightly to the rear. This keeps any moisture on the back wall to drain out the hole and the door will close if left open
Mar 03, 2015 | Kelvinator 12 cu. ft. / 340 liter Chest...
Top door will not close by itself on fridge
Sounds like the floor of the house.. might be your problem..Try moving the fridge out of its position and build a small flat platform in that place and level it, then place your fridge on top of it..just in case u may need a little final adjustment get those small wooden wedge shims when you get your wood..they sell them at lowes or Most lumber yards....that should take care of the leveling..good luck..good luck
Nov 28, 2014 | Electrolux Refrigerators
How do I level my fridge?
It is rare that the rear wheels adjust. Most of the adjustment is in the front wheels. They sometimes put screw jacks in the front as well.
Jul 24, 2014 | Kenmore Refrigerators
How do you install the fridge evenly in the alcove?
#1 is floor level?
#2 does it wobble?
#3 check owners manual-LEVELING THE UNIT there should be adjustable 'feet' that screw into the bottom frame of the unit.some have adjustable wheels at the front.remove the vent panel under the door and look under with a flashlight to see what you have.
Jan 22, 2013 | Fisher Refrigerators
I need to level the refrigerator. The back needs
Hello Monty, If you can roll the fridge out, you'll likely see the adjustment screws for the rear wheels, (if equipped). If the rear wheels are fixed, as most are, you can put a couple of wooden shims down on the floor where the wheels will be and roll the fridge back into place and then make the leveling adjustments from the front wheels.
If the amount of height adjustment is greater than a half an inch, you can use a solid piece of plywood the width of the fridge and about 4-6" wide and place that at the back. Roll the fridge in until it hits the plywood and tilt the fridge forward about 2 inches and push it back until the rear wheels are on the plywood. You can then, again, level the fridge using the front wheel/leg levelers.
I've found that it's easier to get a good idea of just how much out of level the space is where the fridge is being placed. Then you can make the changes using the best materials for the situation. Shims are fine for small adjustments, while the full width plywood is more consistent and easier to adjust, as the fridge will likley get moved out every 6 months or so, for cleaning of the coils and behind the fridge.
Remember that ideally, you want the front of the fridge just slightly higher than the back, so the doors will close by themselves, when opened almost 90 degrees and released by hand. Gravity should then take over and automatically close the doors, ensuring a good seal to keep the fridge closed and running properly.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Maytag MFI2568AE Side by Side French Door...
My comercial washer does not stay level when spinnig,seems like the self leveling device is not staying put ,i can lift it up to level it but it still wants to dance around.
YOUR REAR LEVELING MECHANISM IS SELF LEVELING FROM SIDE TO SIDE YOUR FRONT FEET ARE INDIVIDUAL MAKE SURE THE REAR OPERATES PROPERLY AND RELEVEL THE MACHINE IN BOTH DIRCTIONS. EACH TIME YOU MAKE AN ADJUSTMENT TO THE FRONT FEET WETHER IT BE THE RIGHT OR THE LEFT RE-RAISE THE REAR SO THAT THE REAR ADJUSTMENT WILL AUTOMATICALLY SET ITSELF TO WHAT YOU HAVE CHANGED ON THE FRONT FEET. YOU MAY HAVE TO DO THIS REPEATEDLY TO GET THE BEST POSSIBLE LEVELNESS IN BOTH DIRECTIONS. ONCE YOU ARE SATISFIED THE FRONT FEET SHOULD HAVE A SET NUT RUN THIS NUT UP TIGHT TO THE BASE OF THE WASHER.
Apr 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kelvinator 360 Fridge Wheel Adjustment
If you have the manual.... check under leveling your appliance.
I don't know Kelvinator but most have screws/bolts that can be turned behind the air vent cover at the bottom front of the fridge that will raise or lower the fridge. Sorry I couldn't be of more help.
Jun 30, 2008 | Refrigerators
Samsung fridge freezer rsh1dtmh1/xeu
the only way is to remove the middle wheel right at the front this allows adjustment with the 2 feet at the front
Mar 20, 2008 | Refrigerators
Jenn-Air Pro-Style JFC2089H French Door Refrigerator Logo
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
