Error c26 When i open e studio 243 machine they show me error c26. what will do now please give solution.
  • 653 Answers
SOURCE: erro code c26
C26 indicates Peak Detection Error.
U need to check whether the lamp light on when u ON the machine.
If no, u need to check the inverter cable, inverter board, or exposure lamp.
If light is ON, then u need to perform following:
1. Check if the connectors on the CCD and SLG boards are disconnected.
2. Check if the shading correction plate is dirty.
3. Check if the conductor pattern on the CCD board is short- or open-circuited.
4. Check if the conductor pattern on the SLG board is short- or open-circuited.
5. Replace the lens unit.
6. Replace the SLG board.
Posted on Mar 10, 2009
SOURCE: Toshiba E-Studio 810 says call for service when
check to see if lamp lights. if not, replace lamp.
if lamp lights, pull the platen glass and replace the scanner board under cover by lens.
Posted on Apr 28, 2009
xptareq2000
  • 1447 Answers
SOURCE: Error code L
L signal is scaner lock
please chack your copier left side copy board under lock unlock mark
Thanks
Tareq
Posted on Aug 28, 2009
  • 30 Answers
SOURCE: What is the solution for error code c26 on my
Hi how are you i hope you are well this is jack ..my personal ID.. (jack_pak@hotmail.com)
C26 Error is scanner error
please check the scanner unite
1 scanner lamps.
2 scanner strip.
3 scanner bord
4 LGC bord.
please check these all goods are working properly.
Thanks
Best Regards,
Posted on Aug 14, 2010
SOURCE: my machine toshiba e studio
hai friend it is a small problem ,. the problem is Sensor is not working. U have to do one thing
open right cover., and clean the roller dust., and rearrange all the doors in the printer,. then close tightly the main door., and put a support for not opening ., try it it will work.,
Posted on Jun 08, 2011
Please my heater lamp is not lighting.
U need to check whether the exposure lamp is light ON or not when u turn ON the machine
If not light ON, then exposure lamp unit or connectors might be faulty
Dec 21, 2015 | Toshiba E-Studio 160 All-In-One Laser...
When i switch on ma toshiba e studio 212 its showing me error c26. how can i fix it
it is cis unit error check connection between cis unit and main board otherwise replace cis unit ribbon OR cis unit OR main board
Feb 06, 2014 | Compatible Toshiba T1810 For E Studio 181,...
Toshiba E-studio 166 error code c26
hi. i have problem in my Toshiba e studio 166. that machine toner light is blinking always. i try so many time nd i fixed new toner also. but i cant get any result of this. pls help me to solve this problem....
Mar 07, 2012 | Toshiba e-Studio163 Copier
Tips on C26 code , more info how to fix
[C26] = Peak detection error
Does the exposure lamp light? (Perform the output check in the test mode: 03-267)
If no, Replace the SLG board-->inverter-->exposure lamp.
Oct 07, 2010 | Toshiba E-STUDIO 550 Copier
What is the solution for error code c26 on my toshiba e-studio 550 copier?
1 scanner lamps.
2 scanner strip.
3 scanner bord
4 LGC bord.
Thanks
Best Regards,
Jul 02, 2010 | Toshiba E-STUDIO 550 Copier
Error F14 in my Toshiba e-studio 166
how to reset error code f14 in the toshiba e-studio 160
May 12, 2010 | Toshiba e-STUDIO166 Printer
Call for service c26 in toshiba copier e 810
C26 indicates Peak detection error.
U need to make sure the exposure lamp is light when u switch ON machine.
If no light, then u need to check the inverter and the exposure lamp.
Oct 06, 2009 | Toshiba E-STUDIO 650 Copier
Help
C26 is a peak detection error (when the copier scans the white reference plate there is an error in the detection)
The most common cause of C26 error is the failure the lens unit which is Toshiba's part number 6LA02100000.
The components that fail on the board are IC1 and IC10.
The board can be repaired, but most commonly it is replaced.
May 05, 2008 | Toshiba E-STUDIO 650 Copier
Help me
A C26 code is a peak detection error on your scanner. You'll have to turn off the copier, remove the glass and CAREFULLY clean the mirrors and exposure lamp on the scanner. That usually takes care of the problem.
Apr 08, 2008 | Toshiba E-STUDIO 650 Copier
Erro code c26
12 people viewed this question
k24674
jasbo
jasbo
