Question about Shop Vac 952-02-62 Hang Up Pro Canister Wet/Dry Vacuum
Shop vac hang pro high pitch whistling
High pitch whistling sound when turned on. Any suggestions?
2 Suggested Answers
SOURCE: I have a Craftsman brand
I have the same problem with a CTC Shop Vac. It's he bearings ... they're worn out and dry ... no lubrication. I've trid taking the motor apart and lubricating the bearings, then it runs super for a few uses but then the squealing starts again. Oitch it and buy a new one.
Posted on Oct 12, 2010
My dc33 brush bar won't spin and there's a high pitched whistle. The belt seems to have plenty of tension and I tried the clutch "reset" trick. What do I do next?
Your belt may look fine and spin the brush roll but could still be slipping. There are two belts on your model if it has the clutch to shut off the brushroll. The whistle sound usually indicates a clog or restriction somewhere.
Jun 03, 2015 | Vacuums
High pitch whistle when shark ep754 turned on
sounds like you have some thing stuck in the hose
Dec 28, 2014 | Shark Vacuums
How do I empty the mini shop vac?
Pull out on the clips on each side while pushing on the red part in the center of the clips. Pull black bottom away from the red top while pulling out on the clips.
Dec 11, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Why has our dyson dc14 started to sound out a high pitched whistling noise and lift the exhaust filter breaking the lid ?
Hi there, it's Jack at Dyson.
A whistling noise from your DC14 could suggest a seal or component is out of place. I'm sure we can help trace the issue, and it may be a simple fix.
When you have your vacuum easily to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 13, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Shop vac whistles
If you let it continue, you will have a piece of junk. You take the bolts off holding the motor cover on and you lubricate the upper bushing with oil. They are oil impregnated bushings and will soak up a thin type oil best and last longer. Use 10W or 3-in-1 oil or Marvel Mystery oil.
Jan 01, 2014 | Shop Vac Vacuums
Filter whistle noise
Hi Basil,
I am sorry to hear your machine is emitting a high pitched sound. Based on the details you provided the problem may be isolated to the post motor filter, if so a new filter will be needed. We would like to help with this. Please contact our Helpline to speak with an expert:
US - 1-866-693-9766 or UK - 0800 298 0298
Best wishes,
Jessica
Sep 01, 2013 | Dyson DC25 Vacuum
My motor is getting hot and making a high pitch noise
The motor is getting to hot from insulation around the motor,its a easy fix just remove the insulation and it will not over heat,i had the same problem
Sep 03, 2012 | Shop Vac 84M200 Wet/Dry Vacuum
I have a Craftsman brand shop vac [model # 113.77420]. It is still picking items when I sweep with it, but it has developed a very high pitched squealing sound whenever I turn it on. The sound makes it...
Aug 23, 2010 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
My Kirby G3 makes a loud, high pitch whistle with the hose
I would say you either have something stuck on the impeller or there is a piece of paper or something stuck inside the hose. its not clogging the hose but when the air passes by it. It is making that noise. If you find nothing you may need a repair. May have a bad bearing in the motor. Actually you can also try inspecting the brush on the head. It removes easily from vacuum and should spin freely and quietly.
May 04, 2009 | Kirby G5 Bagged Upright Vacuum
High pitched noise
It sounds like you may have a bearing problem. The motor bearing eventually gets damaged by the water vapor that is drawn in by the fan. This will cause a high pitch squeel from the motor. It is possible to replace the bearing, but it should be addressed by a professional techician.
Jan 27, 2008 | Hoover F5886-900 Steam Vacuum
Shop Vac 952-02-62 Hang Up Pro Canister Wet/Dry Vacuum Logo
Top Shop Vac Vacuums Experts
Mike
Jim Parker
Jim Parker
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
