Question about Beam Industries Vacuums
Beam model bm1383 brushroll
POWER HEAD KEEPS CUTTING OUT
2 Suggested Answers
SOURCE: turbine head brushroll doesn't rotate and no suction
Have you tried washing the filters? The pre-motor filter (the one in the plastic housing) can get really clogged. Hold it up to the light, if you can't see through, it is full of dust. You need to really scrub it with a brush to get the dust out (or buy a replacement). Just a rinse will do nothing. This is something Dyson is not telling you in the manual.
Posted on Dec 18, 2010
We have a Miele Silver Moon vacuum that isn't
Hi dear.There are two type of attachments for this vacuum cleaners to pick up the pets hair,fluff & so on.They call it"Turbo & Power Brush".Turbo brush operates with machines suction & Power one operates with small electric motor which is built in the unit.They work with the same prenciple.There is a belt drives the rotary brush.OK.there are two small yellow screw underneath the unit.Please undo them,take of the cover & clean the rotary brush,check for the belts tension.It should be enough tight to drive the brush.If not ask for spare part from Miele in your country.After cleaning please put it back in order.To test it,attached to the vacuum.Turn the power on for Turbo brush,as long as suction starts,brush should start turning too.For the Power one,there should be power button on the handle to turn it on & off.Press it.It should work.On both of the unit,brush should spin good & strong enough to do the job when it's attached the surface you are vacuuming.Check the brush after each use,cleaned if neccesary. I hope that helps.Thanks.
Aug 01, 2010 | Miele s558 Silver Moon Vacuum
Have power to the head but brushes won't spin
check the brushroll motor for continuity and check the belt and brushroll
Jan 03, 2010 | Bissell 3108 EasyVac Powerbrush Upright...
Green light on power nozzle of Kirby vacuum, Model G7D
The green light is just to inform you that the brushroll is spinning. there is a magnet on the brushroll that makes the green light come on every time it rotates. also why it looks like the light flickers because the magnet only makes contact once per rotation of your brushroll. Let me know if you have any other questions.
Jan 03, 2010 | Kirby Ultimate G Bagged Upright Vacuum
How to change g5 belt
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off)
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again. This releases the tension on the belt
3)Turn it upside down and release the two clips that hold the metal baseplate on and remove the baseplate.
4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt.
You can get a replacement belt here:
Kirby G5 Replacement Belt
Nov 02, 2009 | Kirby G5 Bagged Upright Vacuum
Lubrication for powerhead motor
the power head motor dose need service first thing you should do is take the top cover off by removing the screws on the bottom of power head then remove brushtroll clean brushroll and the end bearings make sure they spin freely squirt some lube (wd40n or tri flow) on the end cap bearings . Then clean motor by blowing it out with compressed air lube bearings with either wd40 or tri flow that should free up the motor and brushroll
May 26, 2009 | Vacuums
Cant rember how to replace the belt on the power head
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off of the Kirby's driveshaft but on the "hook" inside the power nozzle) 2)Remove the power head from the front of the machine. Now that it is off the Kirby, you can turn the square belt lifter until the green arrows line up. (Belt on, which means on the driveshaft on the front of the Kirby when the power nozzle is on the Kirby which makes the brushes spin. Now that the power nozzle is off of the Kirby, the belt isn't actually resting on anything but the green arrows will still point to belt ON ) This removes the belt from the "hook" so that it can be slipped off the brush roll. 3)Turn the power nozzle upside down and release the two clips that hold the metal baseplate on and remove the baseplate. 4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt. 5)Look at the ends of the brushroll. The brushroll has three height settings..you should see notches AND NUMBERS on the sides of the brushroll's end caps. ONE notch (also #1) FACE UP on BOTH sides is the first setting and should be used when the roller is new. Three notches is the last setting used before a new roller is needed and should be used if the brushes are short and worn. Put the brushroll back in, making ABSOLUTELY SURE sure that the SAME NUMBER of notches and the same raised number on the edge are FACE UP on BOTH sides. This is important, as the brushroller will be unbalanced if inserted wrong. Also, one end cap of the brushroll is larger than the other and will only fit onto the larger notch in the power nozzle. 6)Replace the baseplate by fitting the front clips into place and then push it down in back and secure it with the two rear swivel clips. Make sure it fits securely down over the bumper on all sides with no suction leakage. 7)Turn the belt lifter to where the RED arrows line up, making sure that the inner "hook" grabs the belt and stretches it up while you are turning it. Once you have the belt stretched up, put the power nozzle back onto the Kirby and lock it in place. 8)NOW...turn the belt lifter back to GREEN. If the little green light on the power nozzle lights up when you turn it on, CONGRATULATIONS!!! The brushroll is spinning!!
May 17, 2009 | Kirby G4 Bagged Upright Vacuum
How do I replace the belt on my Kirby sweeper---a G4? Thanks!
Hope this was helpful :) and thank you for using Fixya!!!
May 16, 2009 | Kirby G4 Bagged Upright Vacuum
Cant seem to get the green light going on vacuum head,hook seems to be wrong way when its should be hooking the band off its doing the opposite
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again (belt on).
4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt. New brushrolls are available here...  NEW KIRBY BRUSHROLLS
5)Look at the ends of the brushroll. The brushroll has three height settings...you should see notches AND  NUMBERS on the sides of the brushroll's end caps. ONE notch (also #1) FACE UP on BOTH sides is the first setting and should be used when the roller is new. Three notches is the last setting used before a new roller is needed and should be used if the brushes are short and worn. Put the brushroll back in, making ABSOLUTELY SURE sure that the SAME NUMBER of notches and the same raised number on the edge are FACE UP on BOTH sides. This is important, as the brushroller will be unbalanced if inserted wrong.
Apr 18, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I have a model 560kirby how do i put the belt on
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=700350
Generic problem for all Vacuums
Posted by littlemama36 on Jun 23, 2008
I have a model 560 Kirby how do I put the belt on
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. the Kirby you have is an older Kirby with a removable head or you call it a bell housing so you need to dial off the belt counter clockwise and the release the front lever on the bell housing, and then release the bottom plate and remove one end of the brushroll and then slide the belt off of the brushroll. B4 you put the new belt on the Kirby check to see if the brushroll spins freely, also to see if the brushroll is free from the thread and hair buildup, if that is free – then slide the new belt onto the brushroll and the re-insert the brushroll with the screw head on each side facing the carpet and lock down the bottom plate, then use the Kirby spoon/ hook to dial the belt on to the fan pulley and dial the spoon/hook clockwise until the belt is on the fan pulley and the place the bell housing on the Kirby and then lock down the lever so that it is hooked up and ready to go, plug it in and turn it on. If you need further assistance please feel free to contact the local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Lack of Suction
There are actually several possibilities.
Check to make sure that the brushroll is spinning. The brushroll is responsible for virtually all of your pickup on carpet, and is the culprit for most complaints of "lack of suction."
If the brushroll is not spinning, listen at the head to see if the motor inside the power head is active. If you can hear it running but the brushroll is not turning, you have a broken belt. If the motor in the power head is not turning at all you may have an electrical short in the hose, the wands, or the main power outlet from the body of the canister; but before you get too involved check the power head for a thermal reset button. Some of the Electrolux powerheads are equipped with these, and some are not, so check your user's manual. If there isn't one, or if it isn't tripped, you'll need to look for electrical issues.
In this particular model it is fairly common for the electrical contacts on the wands to short out, so inspect the metal contacts to look for scorching, or melting of the plastic around them. If you have access to a VOM, check for voltage at the contacts on the end of the wand, and if it is not present, check all of the contacts sequentially back to the canister body to determine which part is not passing voltage. If you have voltage all the way through the wand, you either have a loose connection inside the power head, or the power head motor has burned out. If you have power from the canister body, but not through the end of the hose, either your hose has a short in it, or the circuit board in the handle assembly that controls the power head power has shorted out.
If your brushroll is turning, then you do, in fact, have a clog somewhere inside the power head, which a visual inspection behind the brushroll and into the elbow will confirm.
Best of luck,
-R
Apr 01, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
26 people viewed this question
Top Beam Industries Vacuums Experts
Thatvacguy.com
Jerry Kramer
Jerry Kramer
Are you a Beam Industries Vacuum Expert? Answer questions, earn points and help others
