Question about Nordic Track Exercise & Fitness
Nordic track commercial 2450
Model No. 19112.2 - the "marker" on the quarter mile track stopped moving. It did work fine and then stopped. What can we do to make it "go" again.
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
  • 18 Answers
SOURCE: my nordic track c2000 apears to start working but
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First, ensure that it is the walking belt that is loose. There is a belt hidden under the hood that connects the front roller to the motor (motor/drive belt). Start the treadmill at 3 or so and carefully apply pressure to the walking belt until it slips/stops. Watch the front roller. If it continues to spin when the walking belt stops, it’s the walking belt. It the front roller stops with the walking belt, the motor belt is loose and needs adjusted or replaced.
To adjust the walking belt, locate 2 hex head bolts, one on either side of the deck on the very back of the machine. These bolts will be recessed inside the plastic covers. Your treadmill came with a tool for this, but if you can’t find it, a standard (not metric) allen wrench kit will work. It’s helpful to have a wrench in each bolt so that you can adjust them at the same time, but one will work.
The allen bolts thread directly through each side of the rear roller. As you tighten the bolts, it pulls the rear roller away from the front roller, tightening the walking belt. This also centers it; if you tighten one bolt, it pushes the belt towards the center of the walking deck away from the bolt you’re tightening. So if the belt is too far to the right, tighten the right bolt and it will move towards the center.
Place your wrenches in the roller bolts and turn the machine on to 3-4 miles an hour. Keep your fingers clear of the belt, it will eat them. This method is quick, because you can see the belt move as you tighten one side or the other. It takes a few seconds, but if you tighten the right bolt for instance, you will see the belt move to the left. If the belt is loose but centered, tighten each bolt ½ turn and then get on the machine and see if it slips. The user manual will tell you to pull it up a couple of inches to test the tightness, which is a relative method and doesn’t necessarily work. My wife can pull on the belt and get 2 inches, and I can probably get 3 or even 4 if I’m showing off. The best way to test it is to gradually tighten it until you can run on it without it slipping.
You should lube the belt a couple of times a year. You can get them from iconfitness.com
Good Luck!
Posted on Mar 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Posted on May 15, 2010
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
Nordic Track NordicTrack Reflex 4500 Pro Treadmill - My belt speed is running about 60% of the speed displayed. What is causing that? Is there a reset feature?
The treadmill is set for kilometers, not miles.
With the stop button pressed, insert the safety key/magnet. This will display miles (or Kms) and hours of use.
There will also be a "M" for metric or "E" for english, or miles. Use the speed up/down buttons to adjust to "E".
Oct 01, 2017 | Nordic Track Exercise & Fitness
Nordic track commercial 1500 no power
looks like there is power to the board. the board the sends power to the console. there could be a loose connection at the board
Mar 04, 2014 | Nordic Track NordicTrack Commercial 1500...
Nordic Track commercial 2150 on the i fit screen starts up but then runs in loops, it will not boot up or
Time to replace the Console board CPU, the Clock+power supply inside had been failed.
Treadmill Doctor
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 08, 2017 | Nordic Track Exercise & Fitness
I have a Nordic track commercial1500 and the belt motor will not run. Everything else works fine. The fuse is good on the board.
1) see if the belt is tight or loose, repair or replace the belt
2) test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulyt, replace see the b.diagram attached.
Jan 09, 2013 | Nordic Track NordicTrack Commercial 1500...
Belt lag nordic track treadmill
DEAR
YOU MUST FIX YOUR BACK ROLLER OF TREADMILL BY FIX SCREW IN END OF YOUR TREADMILL
tend-fc5d3qkuehxyghwmybtp3omc-4-0.jpg you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 31, 2017 | Nordic Track Commercial 2150
How do I get the motor hood off a nordic track commercial 1500
Download a manual for this model . This will make it easier to find the hidden screws.
Apr 06, 2012 | Nordic Track NordicTrack Commercial 1500...
Nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Jun 12, 2010 | Nordic Track Exercise & Fitness
Exercise & Fitness Logo
105 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
