Question about Sony VAIO FRV26 Notebook
How do I get the cover off the Sony VAIO FRV26 PC Notebook
Ok it seems that how to take the cover off this monster is a well gaurded secret or something, but I am really frustrated.
I have taken out all the screws and the front will seperate a bit but it is as if somewhere in the middle or back there are more screws "unseen to me" that are holding it together.
Can someone please tell me how to get the cover off.  My fan is making a noise as if hitting something and I need to check it out.  It's not the normal noise that this beast usually makes, and has nothing to do with it's overheat issues I solved that with an external cooling mat.
I would be so thankful for any help!
  • salieeee Nov 03, 2007
    I have the same sony VAIO frv26 notebook and would like to take it apart to clean out the cooling fan cause it making a lot of noise and overheating. Would appreciate instructions on how to go about it. thanks.
To open an FRV26:
the cover at the top of the keyboard must be removed, take a small screwdriver and run it along the lower edge of the cover behind the top row of keys. there will be 4 small slots across the edge. each of these slots has a small latch which must be pushed in to lift the cover.
once the top cover is removed, there will be a small phillips screw visible at the top of the keyboard, remove it and lift the keyboard out of the way.
under the keyboard is an aluminum shield. there are about 10 small phillips screws holding it down, most around the edges, 2 are down in small tubes. once all screws are removed, lift the cover. the fans will be visible.
WARNING: do not loosen the 4 screws around the fan cover housing. if you loosen these and lift the fans out, the main chip will come with them and must be removed from the heatsink to reinstall.
HTH
Posted on Jan 03, 2008
The same problem here and no solution!!!
Posted on Dec 09, 2007
2 Suggested Answers
  • 83 Answers
SOURCE: How can I get the cover off the Sony Vaio FRV26
get a CAN O AIR and low the whole can through the fan inlet and outlet points its a $1.50 solution whatever it hitting will either be gone or moved outa tha way...VAIO's suck to tear apart
Posted on Oct 28, 2007
How do i repalce keyboard on sony vaio vgn c190g model
first relaese upper cover just onder your display
release the screw's on the back even in the middle in the backside
on the topside theire are also 3 screw's you will have to release. after this ok
Feb 13, 2010 | Sony VAIO VGN-C190G Notebook
Black screen
have you tried checking the day time power saving settings to see if they have been incorrectly set
Aug 29, 2009 | Sony VAIO PCG-K23 Notebook
My Sony Viao will not start up
Easier to re-install windows,,,dont worry,,you wont lose any programs as long as you do a standard re-installation.
and NOT a fresh install.
Jan 16, 2009 | Sony VAIO FRV26 Notebook
Not rebooting
reinstall OS virus problem...
Jul 18, 2008 | Sony VAIO FRV26 Notebook
Sony VAIO PCG-K25 PC Notebook
have you tried your power management settings?
Dec 07, 2007 | Sony VAIO PCG-K25 Notebook
Laptop
it could be that
  • you got a virus that corrupted your hard disk or MBR (Master Boot Record)
  • your hard drive is dead
  • or your hard drive is corrupted
Try booting from a system disk (Windows XP CD, recovery CD or system floppy) and let me know what happens.
Nov 08, 2007 | Sony VAIO FRV26 Notebook
Oct 26, 2007 | Sony VAIO FRV26 Notebook
Sony Vaio PCG-F460
Plug an external monitor into the notebook. See if the diplay is clear. If there is no problem with the display there the problem is with your lcd. You can check for a loose connection by disassembling the notebook. If the connections are ok you have probably done damage to the lcd from the impact of the fall. Now if you are not familiar with working with notebooks internally I would not reommend opening it. Check your warranty with the manufacturer to see if you are covered otherwise take it in for service if you can.
Hope this helps you
Oct 26, 2007 | Sony VAIO VGN-S460 Notebook
Sony vaio r505jl docking station
I googled this and found that both the notebook itself and the docking station have ethernet connections, the docking station ethernet connection seems to be between the usb and monitor connection, The notebook itself has a ethernet connection on the right side of the notebook near the back under a rubber cover. Let me know if that was correct or not.
Oct 16, 2007 | Sony VAIO R505JL Notebook
Computers & Internet Logo
132 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
