Question about Hardware & Accessories
Malibu timer is running but won't turn on lights
2 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: I have a Malibu ML88T timer on the garden lights.
Is the timer wheel rotating - keeping time?
If so, are there pins for the wheel?
The other option is to purchase a photo sensor and let your lights stay on from dusk til dawn. The benefit of this arrangement is that as dusk changes across the seasons and daylight savings time, you don't have to keep adjusting on/off times.
Posted on Dec 01, 2010
Part of a malibu light timer runs but the timer dial does not turn to turn lights on/off
Clock motor has stopped working... there is not replacement module.
Plug power pack into wall timer.
Following link has troubleshoot, warranty, and installation tips to avoid problems:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 22, 2015 | Malibu Hardware & Accessories
Just bought a new Malibu 120 runs a few minutes and shuts off repeat ly after reset
Malibu 120 has photoeye.
At night, the darkness causes photoeye to turn lights ON
Lights located near to the photoeye can cause the photoeye to 'think' it is daytime... so photoeye turns lights OFF...
Then it's dark again because lights are off... so photoeye turns lights ON.
The cycle repeats ON-OFF all night long.
Gene
Feb 15, 2015 | Malibu ML200RT - Low Voltage Power Pack...
Why won't my ml44t transformer turn the connected lights on or off?
1) Copy following link for installing and troubleshooting power pack
2) Test outlet for power.
Temporarily run extension cord from another outlet.
Connect wires to terminals a and b ... make sure no insulation is under screw plate.
44 watt power pack will operate 44 watts of low-voltage lights (12Volt).
If 300 watts of lights are installed on line, then lights probably will not light up.
Mar 01, 2013 | Hardware & Accessories
I replaced an old Malibu 300 watt powerpack with a new digital 300 watt Malibu power pack and when I turn it on it runs for about a miniut and then shuts down. I have 15 11watt light on it, the same as the...
300 watt power pack should have 300 watt load.
You have 165 watt load.
Copy following link for general tips to get Malibu power pack to last longer.
Problem might be the photo eye.
http://waterheatertimer.org/images/Malibu-8100-9045-01-large.jpg
Rotate manual dial to ON position and see if lights turn ON.
Keep in mind the digital power pack has photoeye that is light sensitive, and must be exposed to dark light to activate.
For timed functions. Rotate manual dial until it points at timer. Press clock set function button, and use up-down buttons to set current time. Press timer ON button, and then use up-down to set ON timer. Then press timer OFF button , and use arrow keys to set OFF time.
This product has 1 year limited warranty, contrast with old-type analog power pack with 5-year warranty.
Malibu does not even post a manual on their site, which might have troubleshoot section to illuminate why your system has problem,
http://malibu.brinkmann.net/customer_service/owners_manuals.aspx
Nov 29, 2012 | Hardware & Accessories
Malibu timer motor won't turn on, but it turns off ok. I want to replace the timer unit, where can i get one
The timer module is not sold separately.
Malibu has 5-year limited warranty against defects in workmanship.
If the transformer still works, then plug unit into cheap wall timer.
If the timer dial still keeps good timer, then order trippers.
Copy following link for manuals, tips, replacement tripper numbers and general troubleshoot:
Aug 15, 2012 | Malibu ML300RTW - Low Voltage Power Pack...
ML600 won't turn off
The clock module for power pack is not sold separately.
Set timer to auto using override knob so lights are on, then plug power pack into cheap timer.
Check outlet with circuit analyzer.
Try connecting power pack to another outlet.
Copy following link for warranty information, tips to help power pack last longer, links to trippers, troubleshoot, etc.
Jul 15, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
Won't work timer out
If light still turn on with override, then plug power pack into cheap in-wall timer.
Open following link for ML series troubleshoot steps and information:
Jun 25, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
Clock won't run turn lights on maualy
There are no replacement clock motors for Malibu power packs.
You can buy cheap plug-in timer, and then set power pack to override, and then plug power pack into cheap timer.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 03, 2011 | Malibu ML200RT - Low Voltage Power Pack...
I have a Malibu ML88T timer on the garden lights. I guess the power pack is running can turn lights on off manually but the timer doesn't turn them off or on. Can this be repaired?
Dec 01, 2010 | Intermatic Malibu 300W Power Pack...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
