Question about Koss KS3102 System
No sound but video works
Surround sound was working with TV but not now. Only DVD and Radio works.
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: problem with surround working with just the t.v. on
What type of plug from the TV are you hooking up to the sound system? Its has to be a HDMI or a scart. If its not and your using the rca red and white. The reciver has to be on the synth surrond setting or look in the owners manual, it will tell you what setting the reciver has to be on when using a non surround set or hookup
Posted on Sep 16, 2006
jackboy
  • 2985 Answers
SOURCE: No surround sound when watching cable tv programs.
Looks like cable is not sending the full whack of audio data only Stereo. Or if they are then the set top box{is that how it works in the States?] has a fault. Check out the cable co support team.
Posted on Jun 02, 2007
IrishDruid
  • 2712 Answers
SOURCE: surround sound for DVDs.
If your DVD disc supports it, you will have to enable surround sound from the DVD, as well as the speakers.
Posted on May 10, 2008
No surround sound in TV mode
Surround sound will only work if the source signal is coded as surround. Many older TV broadcast programs are stereo only. If your surround sound is working with a DVD or blu-ray then the broadcast source is the problem
Dec 02, 2013 | Denon AVR-1506 Receiver
I have a 52" mitsubishi
go into the menu and go to audio/video should be able to set your audio from there
Dec 11, 2010 | Mitsubishi Televison & Video
I cannot get sound from the tv through the surround sound, speakers all tested and work ok and dvd sound comes through ok when playing dvd, radio works fine also, worked fine 2 days ago with sharp tv, have...
Hi, You have to make sure you are using the "audio out" from the dvd/surround into the "audio in" on your TV also in some case TVs will need to change the "input" with your remote to see where you connected your dvd/sur also some TVs have a switch for "n" or "off" for internal speakers and also you could have that option in your audio menu on your TV, Hope it help, good luck. Mike
Oct 19, 2010 | JVC TH-G30 Theater System
I have a dvd surround sound and LCD TV both Samsung. The surround sound has no input for coloured cable connection Can I use a HDMI cable from the dvd surround sound unit to the TV to make the TV work as...
Yes, and no. You can connect the HDMI cable from the DVD player to your television for audio and video, but you will not get true surround sound as designed by dolby or dts.
Dec 12, 2009 | Onkyo HTR500 Receiver
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
What to listen to radio, dvd movies and tv in surround sound
we bought a flat screen tv and now surround sound does not work with tv but will work with the radio on surround sound What is w
rong
Dec 17, 2008 | Audio Players & Recorders
No Prologic Surround Sound
im thinking the reciever is set to get its audio from somehwere other than the dvd, sounds like you did most of the troubleshooting but do you get audio out of the reciever if its just playing the radio or something other than a dvd?
Nov 19, 2007 | JVC RX-778V
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Surround Not Working on TV
well for one thing .. on cable it has to be in surround sound.5.1 or 6.1 for it to true surround.your dvd and cd will be fine .. if you just want to have sound coming out of all speakers you have to adjust your sound settings but it will not be surround sound though
Nov 24, 2006 | Sony DAV-DX250 System
Koss KS3102 System Logo
46 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
