Question about Faberware FCP280 Coffee Maker
Need wiring diagram for faberware percolator - Faberware FCP280 Coffee Maker
3 Suggested Answers
SOURCE: electric cord
You can use a computer connection cord.
Posted on Oct 06, 2008
  • 176 Answers
SOURCE: Only a few months old and when we plug it in it
Hi Sharon. ALL Farberware coffee pots make racket. You have a pot that is made in China. When the water is hot the noise stops and it goes into keepwarm mode. As long as your water is hot 175 to 185 it is good. If you were trying to make coffee and you are not perking through the basket is another case.When you want to make coffee you MUST use the cone spring in the pump.That keeps the pump tight so the hot water goes up the pump. With out it the water just boils and does not go through the pump. Good luck. and if you want more info use callahanronald@att.net Ron
Posted on Aug 11, 2010
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
How hot should the coffee be in a Farberware percolator
It should be about 180 degrees. The percolator should perc about one minute for each cup of coffee. If it stops too soon and the water is not hot, then the thermostat is bad. The thermostat can be replaced.
Feb 06, 2014 | Faberware FCP280 Coffee Maker
Vintage farberware percolator does not stop percolating
There is a thermostat in the bottom of the percolator that is broken. It would normally cut off the percolator heating element after the water reaches a certain temperature. It can be replaced but it takes a little skill. There is a video on eBay.
If you want to just unplug the percolator, time it for 1 minute per cup.
Jan 25, 2014 | Faberware Coffee Makers & Espresso...
I have a Faberware percolator and I took it apart to replace the thermostat but the wire broke (prob due to old age and heat). I ordered a new one and now I forgot how it goes back together. How can
Hi. Looking at the prongs with the base off and the handle away from you. One end goes on the left prong and the other to the leg of the high element on the top. Good luck. Ron
Nov 08, 2013 | Faberware FCP280 Coffee Maker
Electric cord
Dec 20, 2007 | Faberware FCP240 Coffee Maker
Faberware FCP280 Coffee Maker Logo
51 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
