Question about Casio CDP-120 88 Weighted-Key Digital Piano
Casio cdp 120 key out of place - Casio CDP-120 88 Weighted-Key Digital Piano
I have a Casio cdp 100 keyboard and two of the keys are stuck in the down position. Almost like the spring has gone in these 2 keys. Can this be fixed and if so, how?
is it under warranty ?
if not
you may have to contact your point of sale to find their local repairer
if you cant un stick them yourself that keyboard will have to be taken apart
are the two keys ... white keys or black ...nearby or way apart
do the two keys drop loose..and lift up
or stay down
example will vacuum cleaner suction help lift the stuck keys or not
sales blurp says this
A spring-less hammer system
Scaled Hammer Action Keyboard
https://www.jbhifi.com.au/musical-instruments/casio/casio-cdp-120-digital-piano/91120
Jul 31, 2016 | Casio Music
How do you replace a key on a casio 100 keyboard. which screws do you remove in the back
What kind/type of your Casio 100?
Casio MT-100,LK-100,CA-100,PT-100,CDP-100 ?
May 19, 2015 | Casio LK-100 Keyboard
How to fix a key with a weight issue
You'll probably have to take it to a Casio repair place, Matty. No weighting at all? Like... light tap gives you fortissimo?
Aug 12, 2014 | Casio CDP200 CDP-200 88 Key Contemperary...
Casio CDP - 120 turns itself off
Casio CDP has Auto Power Off: 30 minutes after last key operation, Auto Power Off can be disabled.
Please read the manual.
If it turns itself off while playing, I would try to buy a new AC Adapter to test. DC cable of AC adapters are often broken internally after much "bending".
Jan 06, 2014 | Casio Music
Casio - 120 Turns itself off randomly
My synthesia dosent work in the learning pack
Transpose the software or the keyboard 12 or 24 semitones up
Dec 24, 2012 | Casio CDP-120 88 Weighted-Key Digital...
How do I save recorded music on my Casio cdp-200R
you would need to hook it up to a pc/mac and via midi and record!
May 08, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Faulty key on digital piano
If it is brand-new, then take it back, and exercise the "warranty" to get it fixed at NO CHARGE to you.
May 29, 2010 | Casio KEYBOARD WK-8000
I have a CDP-100 and need disassembly instructions for access to internal keyboard assembly. Unit was dropped while unloading from car. Now some keys are akimbo and won't play as though they are off their...
I just fixed my CDP 100 which had a similar problem - dropped and two keys not working up one end.
1. Lay keyboard upside down on soft surface. Under keyboard is plastic cover held on by 17 screws. Remove all these and lift cover away. The metal key ends are all revealed.
2. Locate the disloged keys. Carefully press them back into position - they will "click" into place. Make sure the corresponding key on the keyboard isn't stuck in an "up" position - you may have to remove the metal key part and replace it again while making sure the key is correctly seated.
3. Replace cover and screws.
Feb 22, 2010 | Casio Music
Casio CDP-120 88 Weighted-Key Digital Piano Logo
93 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
