Question about Kenwood Car Audio & Video
Kenwood DDX470 No sound when connecting ipod touch to usb
Ipod plays but is not coming through stereo speakers
tech48
  • 624 Answers
SOURCE: aux location
There is a RCA cable that comes off the back of the radio and also another cable for 3.5mm (mini-stereo jack) that also comes off the back of the radio. The RCA jacks can be used for "AUX" or "Sub-woofer" and the 3.5mm jack is just for "AUX". Your ipod can use the audio output jack or the headphone jack and plug that into the 3.5 mm jack on the back of the radio. You will need a "3.5mm male" to "3.5mm male" stereo cord that can be purchased at Radio Shack or Best Buy. Then you select "AUX" on the display with the source button to listen to it. You may need to go into the menu and activate the "AUX" input. Check your owners manual for details.
Posted on Aug 13, 2008
SOURCE: GET IPOD TO WORK ON KENWOOD KDC-W3037 CAR CD PLAYER
you have to activ ate the aux port form the menu, on standby hold the menu button and then use the control knob on the right to change the aux to on1
Posted on Jan 18, 2009
SOURCE: no sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Posted on Feb 28, 2009
  • 265 Answers
SOURCE: Cannot play ipod touch on car stereo
hi there
You will need one of theses:
Click Here
This is a USB to Stero adaptor... will fix your problem for you.
hope this helps
alex
Posted on Apr 06, 2009
SOURCE: Can;t play my Ipod through Kenwood KDC 237
i was just having this same problem but i pressed standby and menu and scrolled up till i got to a AUH which is off all i did was turn it on and press standby again and my ipod started playing
Posted on Jul 06, 2009
I unhooked my battery to do some work on my car when I hooked it back up my stereo screen was black. the red triangle light was on and the fan was but nothing else the dvd would ejet either.works.
after market fitment or factory ?
would say if the fuse is ok
the stereo/ dvd requires a security code
Kenwood DDX470 Manuals
contact kenwood direct and ask question
or cars vin to service division and they can get the code for you
Oct 13, 2016 | Kenwood DDX470 Bluetooth Enabled...
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
on Aug 09, 2011 | Apple iPod touch
Installed kenwood ddx319 stereo but there is no volume
I had a similar problem with the DDX470 in a 2003 Hyundai Sonata. Turns out the car has a factory installed amplifier so the Blue/White wire had to be connected to the Blue/White wire on the wiring harness I had connected to the car. Let me know if you have this wire connected or not, and what type of vehicle you are installing the stereo into.
Nov 11, 2013 | Kenwood DDX319 6.1" Touchscreen LCD...
Kenwood car stereo (DX503) reads Ipod information, but suddenly there is no volume (song name's and artist stream as usual, but there is no sound)
Check your connection from Ipod and the car stereo it might lose or borrow connector wire or bluetooth ( if your using it ) to check the apparatus if its work or check it to the other car stereo with the same model. Check the format requirements of the ipod and car stereo. If this can read Mp3 or Mp4 or any format as it was before. Is your radio and cd player have sound when you play it. If not your Amplifier is not working.
Sep 10, 2011 | Kenwood Car Audio & Video
Kenwood KVT 514 in dash radio. Ipod classic is connected through the usb cable. Ipod is playing and showing onscreen progress, however, there is no audio coming out of speakers. Have been unable to make...
you need to purchase the ipod cable... your ipod is connected through the usb cable which does not provide sound to the unit but everything else works
Aug 15, 2010 | Kenwood KVT-514 Car DVD Player
I have a kenwood KDC-MP438U stereo. Ipod error.
Hi If anything the stereo was probably designed and tested using a certain version of the Iphones software, now that version 4 has been released the way the IPhone communicates may have changed.
As a result the stereo is no longer able to talk to the phone and vice versa. your probably best off contacting Kenwood direct to see if they are aware of this problem and if there is anything that can be done about it.
Jun 24, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
When I plug my iPod into my car stereo, it's a Kenwood KDC-W3041, sound only comes out of the speakers in one door, but when I play a CD, sound comes from speakers in both doors. What's wrong?
If your using the aux plug in the front make sure the plug is fully inserted into the ipod and the stereo. then make sure all audio settings are set correctly. If you are using any other type of connection for your ipod ensure the connection is not loose.
Dec 10, 2009 | Car Audio & Video
My kenwood KDC-MP342U stopped reading my ipod i just got it within the past two weeks and it was working fine and the all of a sudden when i pluggedd my ipod in all it says is reading. i have tried to use...
I had the same problem with my first gen ipod touch. The reset button is on the front panel, between the Fast Forward button and the "1" button. Push it with a pen or something with the unit turned on. It will go dark then come back. You'll have to set up your preamp and other stuff again. I also now push the eject button before removing my ipod or USB thumb drives. The display will flash "remove". I guess this does some handshaking that cleans things up before removal.
Oct 18, 2009 | Kenwood KDC-MP342U Car CD Player
Car Audio & Video Logo
101 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
