Question about Oase Water Trio / Quintet Fountains
Replace water trio bulb - Oase Water Trio / Quintet Fountains
Refrigerator trio water not coming out
the water actuator switch could be bad or the arm broken. The water line could be frozen in the door or the reservoir ion the fresh food compartment. the water valve in back could be bad.
Jul 15, 2014 | Kenmore 24.8 cu. ft. Trio French Door...
Kenmore elite trio
The door switch that controls the lights is acting erratically. Replace it
Search Over 2 1 Million Appliance Parts
Sears Online In Store Shopping Appliances Clothing More
Sep 23, 2017 | Refrigerators
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
No water or ice or lights on outside of door
I received my Elite TRIO 795.7101 2 weeks ago. I have ran over 3 gallons of water though it. I am still getting a bad odor and taste when I dispenser water from the door.
Nov 03, 2010 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
"Failed RH Indicator"
Check your right hand indicator bulbs, front and rear.
Simply a case of changing a blown light bulb.
Sep 17, 2009 | 2001 Jaguar S-Type
Kenmore trio won't make ice
my ice maker won't make ice and sounds like trying to run water into it but isn't filling it up
Sep 11, 2009 | Kenmore 24.8 cu. ft. Trio French Door...
Change ford festiva front light bulb
Hello, the front light bulbs are easily changed by twisting the plastic holder in the back of the lamp that holds the bulb counter-clockwise. You turn it about a 1/4 turn and then it pulls out and you can switch bulbs. Do not touch the new bulb with your fingers because oil from your fingers will cause the bulb to burn out quickly.
Oct 20, 2008 | 1993 Ford Festiva
795.77573600
I just saved my fridge / home too, smelled what I thought to be an electrical fire when I opened the Trio doors, immediately looked at the bulbs as a probable cause, and sure enough, the base of the bulb sockets were burned-brown and the plastic housing was to hot to touch without a hot-mit.
Unscrewed the bulbs and set aside out of children's reach and combustable materials.
I'm filing a complaint and service repair today. 8/3/08
Sean-Jon
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Oase Water Trio / Quintet Fountains Logo
69 people viewed this question
Top Oase Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you an Oase Building Material Expert? Answer questions, earn points and help others
