Question about Lowrance Elite-7 Hdi Sonar/Gps Combo
Elite 7 ,how do you erase the purple track line from day to day
How do you erase the purple track lines from day to day
Purple Lines
Hi i have been researching your problem and it seems this happens alot on these types of telly the problem people have been having is with the pcb formatter board and once this was replaced it solved the problem but when you get this replaced make sure to tell them to check the resistors leading to the pcb board as a blown resistor can cause the problem with the pcb board so get these checked as well.
Dec 14, 2007 | RCA HD50LPW175 50" HDTV
Schematics compaq cq5210y x2
1 - PS/2 mouse port (green)
2 - PS/2 keyboard port (purple)
3 - Video Graphics Adapter port
4 - USB 2.0 ports 4
5 - RJ45 Network (LAN)
6 - Line In port (light blue)
7 - Line Out port (lime)
8 - Microphone port (pink)
Apr 10, 2014 | Dell Audio Players & Recorders
Purple and blue screen on dlp tv
Sounds like a problem with the Vertical Video Card.
Have fun finding one. If your TV is still under warranty... send your TV off for repair.
Oct 03, 2012 | Samsung HL-R5656W 56" DLP HDTV
Thomas the train misty island deluxe set instructions
Starting at the wood cut tower moving clockwise. Tower is 6. 6 to 7 to 8, L2, 9, L4,10,L5,11,fits into tree trunk, 14, (12 connects to the junction) 1, 2, (joins to 13 from the log over.) L5, 3, L4, 4, L4, 5, connects to 6, the tree tower.
The logging tower rails. Connects from 4 to 18, then the tall tower, the rail, the small tower, 17, L2, 16, L4, 15, the tall tree tower, 14, L4, 13 and that connects to No. 2.
L2 is the lowest support. L4 is the middle size. L5 is the tallest.
Nov 28, 2010 | Toys
Thick purple line scrolling up from bottom of screen continually
if it is a uniform pulsating line, then it is the main board or engine. if it is a fuzzy line it is the light tunnel
Apr 26, 2010 | InFocus IN72 Multimedia Projector
I was moving my pionner elite 42 inches and i hit the screen with my head, now there is a big colored big spot,also my kid scratch the screen and make some lines,how can i erase the spot and the lines,can...
If you have a pure White test sceen that you can put on it, try leaving it white for an hour or so to see if you can "burn" it out. If not, your gonna need a panel.
Oct 13, 2009 | Pioneer Elite PRO-950HD 42 in. Plasma...
Wire an AC fan motor
Look at the schematic on the new motor , but i think if the 2 purple wires go each one to each side of the capacitor, the black to line and you need to connect the other line which Im 99% sure is the whte wire which is the only one left.Remember you need 220v between the fan motor lines for it to work.
Sep 30, 2009 | Carrier 38CKC036 Air Conditioner
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | JVC KD-G210 CD Player
PURPLE LINE
if the purple line comes on when your watching tv just unhook any game system hdmi cords or high definition cords other than your cable tv cords
Aug 23, 2008 | Televison & Video
Lowrance Elite-7 Hdi Sonar/Gps Combo Logo
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
