Question about Samsung DVD-VR320 DVD Recorder/VCR
Sys. error code 0506 - Samsung DVD-VR320 DVD Recorder/VCR
AUS cm6780 BSOD ERROR 0x000007E
Debug session time: Mon Jul 14 09:57:27.345 2014 (UTC - 4:00)
Unable to load image atikmdag.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for atikmdag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8800f4d0dbb, The address that the exception occurred at
Arg3: fffff88008f85228, Exception Record Address
Arg4: fffff88008f84a80, Context Record Address
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 00000000000006a8
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80003702100
00000000000006a8
FOLLOWUP_IP:
atikmdag+c7dbb
fffff880`0f4d0dbb 488b83a8060000 mov rax,qword ptr [rbx+6A8h]
BUGCHECK_STR: 0x7E
LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff8800f4d0dbb
STACK_TEXT:
fffff880`08f85460 00000000`00000000 : fffffa80`0ac95a80 fffffa80`09c35840 00000000`00000003 fffffa80`0d6c9010 : atikmdag+0xc7dbb
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: atikmdag+c7dbb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmdag
IMAGE_NAME: atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 53508a3c
STACK_COMMAND: .cxr 0xfffff88008f84a80 ; kb
FAILURE_BUCKET_ID: X64_0x7E_atikmdag+c7dbb
Followup: MachineOwner
2: kd> lmvm atikmdag
start end module name
fffff880`0f409000 fffff880`10319000 atikmdag T (no symbols)
Loaded symbol image file: atikmdag.sys
Image path: atikmdag.sys
Image name: atikmdag.sys
Timestamp: Thu Apr 17 22:13:16 2014 (53508A3C)
CheckSum: 00EAEEE6
ImageSize: 00F10000
Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
Uninstall and reinstall the current driver and if no joy, Try and older version, but nothing over 1yr old. If still not working, try a BETA version if available.
Can't Find Your Driver or Don't Know What Driver to Choose? Please Read This First.
http://support.amd.com/en-us/kb-articles/Pages/find-a-driver.aspx
AMD Graphics Drivers and Software.
http://support.amd.com/en-us/download
***Some generic information on Bug Check 0x7e.***
Bug Check 0x7E: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED.
http://msdn.microsoft.com/en-us/library/windows/hardware/ff559239(v=vs.85).aspx
Resolving stop (blue screen) errors in Windows 7.
http://windows.microsoft.com/en-us/windows7/resolving-stop-blue-screen-errors-in-windows-7
***See if this "HOTFIX" below Applies.***
Stop error message in Windows 7 or Windows Server 2008 R2: "Stop error code 0x0000007E (SYSTEM_THREAD_EXCEPTION_NOT_HANDLED)" or "Stop error code 0x00000050 (PAGE_FAULT_IN_NONPAGED_AREA)"
http://support.microsoft.com/kb/979538/en-us
Machine ID Information [From Smbios 2.7, DMIVersion 39, Size=3043]
BiosMajorRelease = 4
BiosMinorRelease = 6
BiosVendor = American Megatrends Inc.
BiosVersion = F7
BiosReleaseDate = 01/20/2014
SystemManufacturer = Gigabyte Technology Co., Ltd.
SystemProductName = Z87-HD3
SystemFamily = To be filled by O.E.M.
SystemVersion = To be filled by O.E.M.
SystemSKU = To be filled by O.E.M.
BaseBoardManufacturer = Gigabyte Technology Co., Ltd.
BaseBoardProduct = Z87-HD3
BaseBoardVersion = x.xGigabyte Z87-HD3
http://www.gigabyte.com/products/product-page.aspx?pid=4489#dl
Remove.
fffff880`0476f000 fffff880`047b7000 dtsoftbus01 (deferred)
Image path: dtsoftbus01.sys
Image name: dtsoftbus01.sys
Timestamp: Fri Feb 21 04:49:36 2014 (53072130)
CheckSum: 00047544
ImageSize: 00048000
Driver Description: Daemon Tools driver
Possible BSOD issues in Win7
I would also suggest you remove AVG Completely and replace with Microsoft Security Essentials.
Jan 12, 2015 | Computers & Internet
Toshiba 3500c cA90 error code
[CA90] indicates Image data transmission error of sys board.
Check the harness between the PLG board and SYS board open-circuited or the connector dis-
connected?
If the harness is ok, then probably is the PLG board & SYS board issue.
Feb 24, 2013 | Toshiba Office Equipment & Supplies
Error code on toshiba e studio 350 code is f110
Communication error between System-CPU and
Scanner-CPU
Check if the harness connecting the SYS board and SLG board is disconnected or open circuited.
Replace the SYS board. Replace the SLG board.
Mar 07, 2012 | Toshiba e-Studio 350 Copier
Code p2189 code p2187 code p2189pd code 2187pd
P2189: Sys Too Lean at Idle Bank2
P2187: Sys Too Lean at Idle Bank1
The other codes P2189PD & P2187PD are pending codes.. Meaning the car will have to recheck the errors before it calls it an error and sets the engine light on. They are the same codes as the others just the PD at the end means pending.
Jan 22, 2012 | 2005 BMW 645Ci
The copier is giving error code f07
F07 Communication error between boards (LGC and SYS boards)
Firmware is where I would start along with the wall power.
If this isnt work, replaced logic board and updated firmware. Machine will must works perfectly.
Hope this helps.
Oct 12, 2011 | Toshiba e-Studio 45 Black and White Copier
I need the 4 digit code for my memorex TV
memorex TV 0002, 0502, 0506, 0706, 0115, 0704, 0601, 1302, 0428, 0632, 0701 OR 0002, 0502, 0506, 0706, 0115, 0704, 0601, 1302, 0428, 0632, 0701
Aug 16, 2011 | Philips PM3S Remote Control
Pci bus controller
setupdd.sys can be found on your windows xp cd.
Feb 28, 2009 | Dell Dimension 4300 PC Desktop
PROBLEM
here are some link for the error codes hope this helps.
ERROR CODE 7( NTKRNLMP.EXE) .http://support.microsoft.com/kb/812580
ERROR CODE 4 ( SETUPDD.SYS) .http://support.microsoft.com/kb/330181
Sep 18, 2008 | Toshiba Computers & Internet
Help find driver
hi! download you motherboard driver from here!
www.nodevice.com/driver/P5LD2-VM/get34084.html - 15k
drivers.softpedia.com/get/BIOS/Asus/Asus-P5LD2.shtml - 55k -
www.driverfiles.net/Bios/ASUS/P5LD2/download/page,sh,30052,172,6,.html - 60k -
Jul 18, 2008 | ASUS P5LD2 Motherboard
Error message: HD521-2W
this error is basically a fatal error. you will endd up needing to replace your hard drive soon but if you dont like doing a recovery every few days and loosing your information all the time replace the hard drive
Mar 30, 2008 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Samsung DVD-VR320 DVD Recorder/VCR Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
