Sounds like a timing problem to me.... There is an adjustment you can make, but it's a "trial & error" fix: you have to make an adjustment one way or the other in the camstack, and then see if it's worse or better (relative to a correct slide cycle). This adjustment is made with the projector upside-down with the bottom cover removed. Check out the attached picture for more detail on where & how to make the adjustment.
SOURCE: Kodak Carousel 600 Projector - mechanism stops with slide out
Open the back up and spray just a LITTLE bit of WD-40 into the cavity where the bit of spring emerges from the grease covered cam shaft. This will loosen up the grease that has dried up. It may take up to half an hour to work on the grease. If things are improved but not perfect, repeat. If any WD-40 spills out, mop it up with Q-tips and especially avoid the rubber belt.
Please do NOT advance things manually ans especially don't pry apart any of the plastic or metal cams on the cam shaft in an effort to correct the timing. You will put it out of waht and it will take a whack of time and/or an expert to get it back in whack!
SOURCE: Kodak Carousel 760H wont advance or reverse
Yeah. I like the $15 fix better. Go to Ebay and search for "Kodak Carousel Projector Advance Repair Kit". Before you purchase you can diagnose, and it comes with detailed instructions. The same guy also has a kits for other common problems, as well as the "tune up kit". Or you can buy the Solenoid Link, directly and try it without detailed instructions.
SOURCE: Kodak 650H projector - won't advance. Hadn't used
The wire is probably from the circuit board or the motor. The location of the wire may vary depending on the age of the projector.
But the problem you have sound like a broken solenoid "Link". The "link" connects the cycle solenoid plunger to the cycle lever in the slide change mechanism. The "link" is made of plastic and over time gets brittle & cracks. Once this happens, you will hear the noise of the cycle solenoid engaging (click), but nothing will happen. The good news is parts are still available (www.micro-tools.com). This is not an easy repair, and I would recommend contacting a factory-trained repair dealer.
SOURCE: Automatic slide changer is stuck in
The problem is continuous cycle (like you don't know that already...). It indicates that an adjustment to the cycle contact is necessary. To open the projector, first unplug it and remove the lamp module from the rear of the projector. Turn the projector upside down. Remove the 6 - T15 TORX screws from the bottom (5 around the perimeter and one in the channel next to the cord wrap). CAREFULLY pull the bottom off (the power wires connect the bottom cover & top together!!). Once you have it open, leave the projector upside down, put on your safety glasses & plug the projector into the wall. At the center of the projector you should see a hub rotating about every second or so. Above it you should see a "J"-shaped wire. See the attached illustration.
You will have to, in repeated steps, unplug the projector, bend the "J"-shaped wire GENTLY & SLIGHTLY, plug the projector back in and cycle it a few times. Check for the position of the "J"-shaped wire to the pad, and GENTLY repeat until you achieve the position shown in the illustration.
Good Luck !!
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
