Question about Zanussi FJS1225W Front Load Washer
Zwh7160p conditioner tray won't empty - Zanussi FJS1225W Front Load Washer
Carrier holiday elite 12
I believe this means you need to empty the water catch tray. Normally a pull out tray at the rear with a float arm in it. It will keep happening as the water is condensed out of the air during the dehumidification. Empty it out and start again, it will need regularly emptying.
Jun 02, 2013 | Heating & Cooling
LG v181 won't eject - it tries to load even when there is no disc and won't slide out the tray at all.
It's likely a belt that drives the tray has snapped or come off! If you take the top off you might well see it!
Dec 23, 2012 | LG V181 DVD Player/VCR
Portable Air conditioner alarm won't stop
Sadly, if you still are not able to find an answer, it probably mean that the sensor is messed up and the best and cheapest option would be to get a new air conditioner unless you want to take it in to a repair shop and see what their quote for fixing it is.
Nov 29, 2012 | Heating & Cooling
Conditioner won't empty in the compartment in
Conditioner won't empty in the compartment in washing machine This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 07, 2012 | Hotpoint Washing Machines
Took the tray out to empty it, put it back in but now it says tray empty and won't work
Check the two contacts at the back of the tray. Be sure they are cleans as well as the plastic space between them. Then using compressed air clean where the contacts enter the machine in the rear. Usually there is moisture back there and the machine assumes the tray is full of water.
Jul 26, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
I'm getting a P2 error when I turn my LG Air conditioner to either cool or auto. I empty'd the water tray and it continues to have this issue. Not sure what else to do.
there is a plug in the bottom of the unit its a condensation tray that needs emptying as well not just the lift out tray happy to help
Jul 10, 2010 | Danby DPAC8020 Air Conditioner
Washing machine will not draw fabric conditioner
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
Aug 23, 2009 | Bosch Washing Machines
Runs fine, fans are fine, cools just fine, but I've had to empty the condensation tray (with the little bobber) a lot in the last three days. it overflowed yesterday and I had a mess, it works when I empty...
Sounds like from your info you have a stopped up drain line. When you say tray I am not sure what you are going to empty. Does the unit empty into a condensate pump. If so sounds like you have a pump problem. If you have a small pan underneath the ac unit with a small float. If this is filling up. You have a stopped up drain. If you can blow out the drain from the inside good. If not the best way is to take a shop vac and **** from the outside drain line. BEST pulls everything out. Rus
Jul 04, 2009 | Ruud UBHC Air Conditioner
Conditioner tray won't empty
i assume the detergent drawer is really clean especially the conditioner part.fault may be that the roof of the detergent box (the part the drawer goes into) is clogged. open drawer half-way at point conditioner should be taken and check if there is a spurt of water into the conditioner section. if not push a hairgrip or similiar into the holes in roof of box as you may have a blockage there.
Mar 28, 2007 | Electrolux EW1000i Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
46 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
