Question about ViewSonic Optiquest Q9b 19" Flat Panel LCD Monitor
Have to restart to make my keyboard work
When I turn on my computer, the keyboard does not work. When I restart it, it works.
Sony vaio palmrest dead
make sure the kb turned on
make sure you got a good connection
make sure plus or usb connectors are clean
if you have ir or rf device make the rf box plugged in
than check the batteries in both devices
than push the button on the rf connector and keyboard at the same time and restart the computer.
than push rf connector the mouse button at the same time and restart the system again.
if the keyboard still not working try a different keyboard if bother keyboards do the same thing
turn off computer when you restart the computer push F11
go into cmos check keyboard turned on
F10 save and exit reboot.
Jan 22, 2014 | IBM PALMREST W/O TOUCHPAD 91P8399
My KEY BOARD IS NOT WORKING
1. Restart your Computer at once. 2. If it doesn't work Turn off your computer and remove the keyboard from your computer and replace again. 3. If it doesn't work too, you need to change the key board. thanks
Aug 30, 2011 | Gateway 2520915 Keyboard
Mouse works fine, keyboard stopped working..has fresh batteries in both
Check for a buttom anywhere on the keyboard that says connect. or a reset button. Any button on the keyboard might be the button that you need to press to tell your keyboard to start sending information to your computer again.
If this does not work. Turn off your computer. Restart it. And try the same thing again after restarting your computer.
Apr 12, 2011 | Computers & Internet
New microsoft wireless keyboatd not working
You need to install the keyboard drivers. Try restarting the computer while the keyboard is plugged in. If this does not work, navigate to the control panel and turn on the on-screen keyboard. Use this to search the internet for the drivers for your keyboards drivers. Once you find them, install them and restart your computer.
Feb 27, 2011 | HP D8597A Keyboard
The keyboard completely stopped working. Unable to type at all...any suggestions? I have disconnected and reconnected the keyboard and restarted the computer.
Turn off the computer, disconnect and reconnect the keyboard, restart your computer. If that does not work, try a different keyboard. If that still does not work than try a usb keyboard instead of a ps/2 keyboard or vice-vers. Good luck and let me know how it goes.
Aug 29, 2010 | Compaq Keyboard
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    Keyboard stopped working completely.
    To, Fix the problem, do the following. Shutdown the Computer, Disconnect the keyboard from the computer, and unplug AC (adapter) from power outlet. Reconnect in reverse order. Turn on the computer. Turn on the keyboard. Go, to Control Panel; click on Device Manager. Click to open Keyboards, in the (Keyboard Properties) Click on Driver (Box), next click to "Update Drivers!"Click OK. Restart the computer. Check keyboards’ functionality.
    Jan 17, 2010 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
    Keyboard and now monitor work when they want to
    Its not problem with key board.
    your RAM has become weak to start normal windows
    get your RAM replaced
    pls rate me
    thank you
    Feb 14, 2009 | eMachines W4620 Keyboard
    Stoped functioning
    Normal 0 Turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
    If your having trouble with the mouse also,
    turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
    Hope this helps. Bud
    Dec 03, 2008 | Microsoft K5100141 Keyboard
    ViewSonic Optiquest Q9b 19" Flat Panel LCD Monitor Logo
    15 people viewed this question
    Top ViewSonic Computers & Internet Experts
    Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
