Question about Staples SPL1506X (CrossCut) Shredder
Shredder blades won't spin - Staples SPL1506X (CrossCut) Shredder
I have a staples SPL826X shredder and it won`t shredd, but it will go in reverse. can someone help me?
If you can disconnect the power to unit and check shredding blade alignments to see if there is a clog or if the blades are out of alignment and stuck. If there doesn't seem to be a problem with the blades make a visual inspection of the off/on/reverse switch.
Nov 28, 2014 | Staples SPL826X (CrossCut) Shredder
How to lubricate a Black & Decker Model BD-s600 paper shredder
    • 1 Turn the paper shredder off and unplug it.
    • 2 Clean out the paper shredder. Make sure the blades are free of paper bits and debris. Remove pieces of paper that are jammed around the blades.
    • 3 Spray the shredder oil through the blade opening or throat of the shredder. Spray it in a stream.
    • 4 Plug the shredder back in and switch the reverse button on. Then run it for 10 to 30 seconds in reverse to allow the blades to be saturated with shredder oil.
    • 5 Put the shredder in forward motion and let it run again to disperse the oil thoroughly to all areas of the cutting blades.
    • 6 Feed a couple pieces of paper through the blades to be shredded and absorb any extra shredding oil.
Read more: How to Lubricate Paper Shredders ' eHow.com http://www.ehow.com/how_5761042_lubricate-paper-shredders.html#ixzz1kDQGrxZ8
Jan 22, 2012 | Office Equipment & Supplies
My chipper hums when i turn it on but the blades dont spin. I took it apart and cleaned it, the blade is freely spinning by hand. put it back together and it still just hums. what next?
I would say a bearing or armature mount is loose. When the power is applied the magnetic fields are pulling the armature up against the other coils. I have had this happen to me before and the problem was the bearing slipped out of its mount. A rubber mallet fixed it.
Sep 04, 2011 | McCulloch Electric Chipper Shredder
So i put in 9 or 10 sheets to shred and it has jammed. I know, i know yet it won't reverse or go forward the blades are stuck, I got out as much paper as i could and it's frozen. please help me!
The only thing left to do now would be to take the bottom cover off... then take apart the assembly and pull out one of the blades to get the rest of the paper out...then reassemble the machine...
Hopefully you have not totally ruined it...
heatman101
May 20, 2011 | HSM 108.2CC Shredder
Blades are stuck... Motor is running but blades aren't spinning.. Please help?
If motor is running but cutting blades are not turning then most likely you have a damaged/broken gear inside. You will have to open it up to see which gear then contact manufacturer for parts assistance.
Jan 14, 2011 | Martin Yale 1000 (Cross-Cut) Shredder
Shredder not working and red light on
Overpacking the shredder can cause the trigger on the arm that is attached to the wheels that help spin the shredder blades, if this is not in the right place your shredder will not work.
Aug 21, 2010 | Aurora Electronics AS662C Shredder
Od700c shredder: motor spinds, blades don't move
Inside the motor assembly there are a series of nylon cogs , a large one of which interacts with a metal one.  This is the most likely place you have one or two teeth missing from the large nylon cog that drives the shredder blades.
Sep 22, 2009 | Fellowes OD700C Shredder
I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
Sep 01, 2009 | Royal Office Equipment & Supplies
Reverse works, but will not run when paper is inserted.
Bad/dirty start switch, if you can get to it clean it with alcohol and blow it dry.(paper dust gets on the contacts)
-carl
Jul 07, 2009 | Tech Solution TS-4500 Shredder
Staples SPL1506X (CrossCut) Shredder Logo
65 people viewed this question
Top Staples Office Equipment & Supplies Experts
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
